griz Posted December 8, 2008 Report Share Posted December 8, 2008 i have a older fireplace with gas logs that is having problems with lighting? sometime it light, but more now not lighting. i can see it sparking but it act like is not getting gas though the valve. is their way to clean it and readjust? thanks Griz Stivers Link to comment Share on other sites More sharing options...
StevenT Posted December 8, 2008 Report Share Posted December 8, 2008 Griz, There are a few things that could cause problems igniting your fireplace. Be smart and get someone that knows what they are doing to look at it. Whatever it costs, which probably won't much, will be well worth it if you can avoid a fire or an explosion. Somtimes it's cheaper to go first class, get it done right the first time. Link to comment Share on other sites More sharing options...
Les Posted December 9, 2008 Report Share Posted December 9, 2008 Griz, Steven is right about having a tradesperson look at it. Does not sound like a costly repair, likely clean and adjust. Gas logs are usually very simple and can be very dangerous. Get it repaired and curl up with the cubs! Link to comment Share on other sites More sharing options...
msteger Posted December 9, 2008 Report Share Posted December 9, 2008 Ditto to what the others say. Call a qualified fireplace technician in to service/repair the gas fireplace. Link to comment Share on other sites More sharing options...
