Doug welborn Posted September 23, 2008 Report Posted September 23, 2008 This house had trusses that appeared not to have been bought, there were hardware stickers on the nail plates. One of the trusses had been cut, how should I Image Insert: 522 KBaddress it?
hausdok Posted September 23, 2008 Report Posted September 23, 2008 Hi, Got other pictures? That photo doesn't really explain a whole lot and makes it hard to put the picture in context despite your explanation. When you take photos of something in a house, you should first take establishing shots of the whole area - in the case of an attic, of the whole section of the attic viewed from well back - so the viewer can gain perspective into what it is you're trying to show them in the photo. Then, move closer to the object in question and take more pictures moving from a general picture of the object to specific shots of what it is you're trying to focus the viewer's attention/concentration on. They might be site-built trusses, or not. Certainly, if that's supposed to be the splice between a truss chord and a web it's dicked up but one can't possible tell you more than that from looking at that close-up photo of...what? ONE TEAM - ONE FIGHT!!! Mike
Brandon Whitmore Posted September 23, 2008 Report Posted September 23, 2008 If you're talking about that vertical member, it is turned the wrong direction by 90 deg. I wouldn't think that was a truss member as a result. Also, is there a bearing wall where the bottom chords/ floor joists rest in the center of that photo (that would make it not a truss system). Oh yeah, what Mike said too.................. can't really see much.
Jim Baird Posted September 23, 2008 Report Posted September 23, 2008 Doug, Is there any chance this is a modular house that was factory made in big pieces and hauled to the site for assembly? I have seen those kinds of cut pieces that were simply bracing members installed for shipping of modulars, and are routinely cut away during assembly.
