Jerry Simon Posted August 20, 2008 Report Posted August 20, 2008 I don't think it's electrical, so if not, pardon the post in the Electrical Section. House built 1914. This was in the second floor hallway. Inside, a tube, similar to a central vac tube. What is this (Kibbel)? Image Insert: 2035.03 KB Image Insert: 2087.22 KB
Jim Katen Posted August 20, 2008 Report Posted August 20, 2008 Originally posted by Jerry Simon I don't think it's electrical, so if not, pardon the post in the Electrical Section. House built 1914. This was in the second floor hallway. Inside, a tube, similar to a central vac tube. What is this (Kibbel)? It looks like an old central vac system. They did exist then. Pittock Mansion, in Portland, was built between 1909 and 1914. It sported a central vac system and an intercom system. From the flamed oak trim in your pictures, I'm guessing that this was a high-end house that might have included such a spiffy innovation as a central vac system. Was it? - Jim Katen, Oregon
Chad Fabry Posted August 20, 2008 Report Posted August 20, 2008 From the flamed oak trim in your pictures.... It looks like quarter sawed oak that's a hundred years old. Does 'flamed' mean highly figured with lots of specs and rays?
Jim Katen Posted August 20, 2008 Report Posted August 20, 2008 Originally posted by Chad Fabry From the flamed oak trim in your pictures.... It looks like quarter sawed oak that's a hundred years old. Does 'flamed' mean highly figured with lots of specs and rays? Yep. - Jim Katen, Oregon
Jerry Simon Posted August 20, 2008 Author Report Posted August 20, 2008 Originally posted by Jim Katen Originally posted by Jerry Simon I don't think it's electrical, so if not, pardon the post in the Electrical Section. House built 1914. This was in the second floor hallway. Inside, a tube, similar to a central vac tube. What is this (Kibbel)? From the flamed oak trim in your pictures, I'm guessing that this was a high-end house that might have included such a spiffy innovation as a central vac system. Was it? - Jim Katen, Oregon Yeah...high-end at one time. Now a depressed area...historic district of Elgin, IL. Image Insert: 2195.99 KB
SonOfSwamp Posted August 20, 2008 Report Posted August 20, 2008 The thing could be a speaking tube. Are there similar openings in areas that servants might have occupied? Swell house. WJ
Jerry Simon Posted August 20, 2008 Author Report Posted August 20, 2008 Originally posted by SonOfSwamp The thing could be a speaking tube. Are there similar openings in areas that servants might have occupied? Too low, don't you think? Swell house. Not...frayed, torn-off asbestos all over the basement heat pipes, insulated-over knob & tube, basement seepage so bad every support column base completely rotted, fire-damage all over the attic (mostly hidden by newer looking drywall), significant leakage damage under two low-slope roof section, stucco repaired by cutting tubes of caulk in half and mushing into place, Federal Pacific panel, minimal water flow due to calcium-clogged pipe...and that was some of the better stuff. Ya think they woulda fixed something over the years, but maybe not; neighborhood took a dive. Handsome house, though. WJ
AHI in AR Posted August 21, 2008 Report Posted August 21, 2008 Originally posted by Jerry Simon Originally posted by SonOfSwamp The thing could be a speaking tube. Are there similar openings in areas that servants might have occupied? Too low, don't you think? Handsome house, though. Of course the hole was not too short. People were shorter in those days. Especially the working class![] Seriously, though...it would be a shame to see that home wither away due to neglect.
Bill Kibbel Posted August 21, 2008 Report Posted August 21, 2008 It sure looks like an old central vac hose inlet. I've seen a few in residences, but many more in old office and apartment buildings. They called them "stationary vacuum cleaning systems". The earliest was part of the original construction of a 1910 building. I saw one in a home that was a "hydro vacuum". It had a water powered "suction generator" in the basement. When you finished vacuuming, you would flush the waste into the sanitary sewer. It was really cool system.
Jesse Posted August 23, 2008 Report Posted August 23, 2008 A couple years ago some one posted a similar photo, and it was for an older electrical receptacle. Some one else even posted photos of a light fixture or a toaster(?) to go with that type of receptacle. It's a different kind of cover plate, I know. I bring it up because I want to see those photos again! Anyone?
Bill Kibbel Posted August 23, 2008 Report Posted August 23, 2008 Originally posted by Jesse A couple years ago some one posted a similar photo, and it was for an older electrical receptacle. Some one else even posted photos of a light fixture or a toaster(?) to go with that type of receptacle. It's a different kind of cover plate, I know. I bring it up because I want to see those photos again! Anyone? Receptacles used to be "sockets" before bladed plugs were the standard. You could plug in a bulb or appliance anywhere. here it is: www.inspectorsjournal.com/forum/topic.asp?TOPIC_ID=3544
Bill Kibbel Posted August 23, 2008 Report Posted August 23, 2008 Originally posted by inspecthistoric I saw one in a home that was a "hydro vacuum". It had a water powered "suction generator" in the basement. When you finished vacuuming, you would flush the waste into the sanitary sewer. It was really cool system. [
