Don Lovering Posted July 11, 2008 Report Posted July 11, 2008 A bit of background first: The house suffers a broken pipe second floor that floods the first floor of a Cape. Clean up and repairs complete, the water issues have been dealt with by a national clean-up comapny. Part of the cleqan up was to apply a polyeurithane to the ceiling of the basement, which is the first floor frame. A year and a half later, a fungus is growing on the eurathane A nice white and pale green color. Moisture levels are in the 10 to 12% range on the unsealed stair stringers. Anyone have a clue as to why? Or even has anyone seen this ? One thought was it was a reaction between the sealer and the cleaning chemical, but it looks like it is originating on the surface[?]
Scottpat Posted July 11, 2008 Report Posted July 11, 2008 Why would they apply Polyurethane to the ceiling? Would this not now create a sealed space? Kind of like putting plastic sheeting over drywall. The normal moisture (RH) that would normally occur in the basement is now trapped and has no place to go.
StevenT Posted July 11, 2008 Report Posted July 11, 2008 Was the entire basement ceiling polyurethaned? If so, ditto Scott. Are you sure it was polyurethane? "Stainkiller" , used to prevent water stains and etc. from bleeding through, is actually varnish.
Les Posted July 11, 2008 Report Posted July 11, 2008 well, the real industrial stainkillers are alcohol based shellac and mold loves it! The other consideration is it was varnish and that is a food source. My opinion - it was a dumb move that I would expect from a "skilled homeowner" not a professional mold for gold company.
