RickSab Posted July 3, 2008 Report Posted July 3, 2008 I found this at yesterdays inspection. When you look at the chimney you have from top to bottom the water heater flue, the furnace flue, and then the mystery flue? It has a black hose coming out the bottom draining into a old glass jar. The flue pipe is cover has a handle, but the cover has been crimped or soldered on. There is another flat cover below and then a clean out. There is no rain cap outside so I suppose it could be rain water? Another interesting item is the power to the Carrier gas furnace runs through a fused 30amp disconnect listed as a Oil Burner Shut-off. The basement is practically sealed with drywall so I can not locate any old oil supply lines and the small yard is completely concreted over so no indication of a tank. What do you guys think? Image Insert: 38.71 KB
hausdok Posted July 3, 2008 Report Posted July 3, 2008 That's because it's an old oil burner thimble that's no longer used and that's where the smoke pipe from an oil furnace used to enter that stack. Some creative fellow figured out that flue gases would condense in there and cause rust stains on the wall under that cover, so he's fitted the cover with a little condensate drain. When they take an oil furnace and tank out of commission in your area, does state law require them to obtain a permit and have it decommissioned a specific way or is it kind of wide open? If there is a law requiring a permit, you can make a phone call to whoever is responsible for those records and find out if a permit was ever issued for that home. If no permit was issued, you've got probable cause to report the possible presence of an abandoned oil tank on the property and should instruct the client to demand proof that it's been properly decommissioned. Lacking proof, the client should demand a survey to see where the tank is and determine if it's still got oil in it and/or has leaked, and then have it decommissoned if one is found. ONE TEAM - ONE FIGHT!!! Mike
RickSab Posted July 3, 2008 Author Report Posted July 3, 2008 That makes sense. I'll check on the permit but because this is a flip and an obvious one I don't think anything had a permit. Thanks for the help. Too bad the guy didn't tell anyone to empty the jar.
RickSab Posted July 3, 2008 Author Report Posted July 3, 2008 Interesting enough the village will not say until I file a freedom of information request. I guess that good. I'll indicate the possibility in the report and even that they could file report to find out. It 1.5 hours to close for a holiday weekend. I don't think I'll get an answer in time.
Mike Lamb Posted July 4, 2008 Report Posted July 4, 2008 I believe that is the the often required clean-out for a masonry chimney. There are thousands of that type around here. You are right. The hose is for draining rain water. Slick.
hausdok Posted July 4, 2008 Report Posted July 4, 2008 Hi Mike, I don't think it's the clean-out. You can see it lower down on the wall. OT - OF!!! M.
Mike Lamb Posted July 4, 2008 Report Posted July 4, 2008 Originally posted by hausdok Hi Mike, I don't think it's the clean-out. You can see it lower down on the wall. OT - OF!!! M. Could be, but I see these things all the time when there is a metal liner in a masonry chimney.
