I can't seem to recall what the minimum spacing allowed for roof sheathing to a chimney/metal vent. Today, I saw plywood directly up against a wood burning fireplace's chimney and called it out as a potential pyrolysis and fire hazard, but can't recall the exactly minimum requirement. Is it 2" min spacing b/w chimney and framing or plywood?
Believe it or not, the seller also had plywood nailed up against the chimney in the garage as well.
Thanks in advance.
The manufacturer's stickers usually mandate a minimum of 2" clearance from combustibles. I always take a photo of the sticker to show my customer.
Thanks. I don't recall seeing stickers on metal vents very often. The 2" spacing only pertains to B (double walled metal) vent, correct? The single walled stuff needs to have more clearance like 6~ 8" if I recall.
Hi John,
Just resize them on your own computer then go back to your post, click the "edit" icon, delete the old photos, upload the resized ones, and then click "submit changes."
  • 1 month later...
