What do you guy's think of these details. I often see this trim detail in areas that are not that exposed and don't usually see a problem with them. This is on a 3 level home with no eave protection. I don't like how it looks like water will get diverted into the house wall when it rains.
Image Insert:
5.59 KB
Looks like what you have there is all too often just what I see here. A job that looks good from the buyer's car but won't keep water out. The problem is that the damage won't likely show up until after all warranties are up. Around here it won't, anyway. Your neck of the woods sees more rain. The mfr admits that their siding will let water get behind it. Therefore, there must be additional flashing and barriers installed. The problem is that all too often no one takes responsibility for seeing that those things are done.
The horizontal bands are a particular problem. A board clad in aluminum with no head flashing and only an inverted "J" channel on the bottom side. Nothing to keep water from getting behind the siding.
But hey, it's vinyl...the ads say it's maintenance free!
Right????[;)]
Originally posted by Brandon Whitmore
What do you guy's think of these details/
I think they're painfully common. They leak like sieves. If the water resistive barrier underneath the vinyl isn't detailed perfectly, it's a mulch farm in a year.
Ideally, head casings and drip caps at any horizontal break in the siding.
Never see 'em....
Thanks for the back up guy's. It's like this on the entire 30 unit complex and the HOA is gonna love it.
Luckily, the units aren't that old and I couldn't see any damage where I peeled back the materials. I spend half an hour looking for damage and found none, which surprised me.
They probably had the underlying details correct. Finding leaking vinyl is normal; it's "supposed" to leak. Waterproofing is about the moisture barrier underneath.
Those are pretty ugly details. Unfortunately not too many people, installers incuded, realize that even properly installed vinyl allows up to 20% of the water that hits it to go through it. Underlayment is key to keeping the building dry.
With the level of detail on those buildings that siding should take in the range of 10-12 man hours per square to install and detail properly. I'll bet that there aren't that many hours into the siding you have pictured.
Tom
I just noticed on the installation details I posted, that the manufacturer calls for the bottom piece of window flashing to overlap the piece of siding below. I have never seen that detail before. I can't grasp how that would be properly done.
Has anyone installed vinyl siding with the bottom piece of window flashing installed to drain directly to the exterior?
Phillip,
I have only installed the stuff a couple of times, and can't quite grasp how it would be done.
It seems like the flashing would stick to the vinyl as it expands and contracts and damage the flashing or loosen it up. Does the flashing get "locked" in between sections of the siding?
While we are on the subject of vinyl, I thought this would be an interesting addition. My dad installed vinyl on the home he (we, kind of) build in the early '80s. I pulled off the siding on one wall to do some repairs and replacement of sheathing. The Tyvek housewrap was completely shredded along the entire wall. I looked like the expansion/ contractor of the vinyl was shredding the material. It makes me wonder how effective a properly installed housewrap is behind this material.
The flashing I used is a flat piece of metal. I would slide it under the nail flange at the bottom of the window and it would end on the top of the nail flange on the siding where the water would drain into the bottom of the piece siding that when on next.
