John Dirks Jr Posted May 10, 2008 Report Posted May 10, 2008 Is this blown in cellulose? It is finer ground material than I have seen before. Image Insert: 133.9 KB Image Insert: 86.75 KB
John Dirks Jr Posted May 10, 2008 Author Report Posted May 10, 2008 There was maybe 4" on average up there. Thanks for the quick replies.
msteger Posted June 24, 2008 Report Posted June 24, 2008 Originally posted by John Dirks Jr There was maybe 4" on average up there. Thanks for the quick replies. Wow.. only 4"? That's only about an R-14. I would recommend adding more. Often times I'll see it in huge clumps in one area of the attic and almost none in another. In that case, I recommend leveling out the insulation to provide a more uniform thickness, which will help provide a more uniform and even insulation R value.
