John Dirks Jr Posted May 8, 2008 Report Share Posted May 8, 2008 I'm cheap and I bought a used hex shaped patio set at a yard sale. It was well worth the few dollars I paid for it. I need to build a hex shaped platform to set it on in my back yard. I'm looking to make it about 10' across or so. I'm thinking of embedding it into the ground so the edge is just an inch or so above grade. No footings needed, I dont care if it floats. I'll just adjust it when needed. Any suggestions on what materials to use to make this thing as cheap as possible. Pressure treated for sure but how about the design? Can anyone direct me to some plans or ideas to get this thing slapped together. The chairs dont work too good when the legs sink into the dirt and gravel. The only purpose of the platform is a place to set the table and chairs. Link to comment Share on other sites More sharing options...
randynavarro Posted May 8, 2008 Report Share Posted May 8, 2008 Concrete pavers. Material is pretty cheap but the labor to do it right can kill ya. Why a hex shaped patio? Maybe just square or, if you're really ambitious, round. Link to comment Share on other sites More sharing options...
Brian G Posted May 8, 2008 Report Share Posted May 8, 2008 I'm not sure what to tell you, sight unseen. If you use wood, you'll be making a lot of 30° cuts. Brian G. Break Out the Chop Saw [:-party] Link to comment Share on other sites More sharing options...
John Dirks Jr Posted May 8, 2008 Author Report Share Posted May 8, 2008 Look at the second picture in this link. http://www.creativehomeowner.com/index. ... d=chyrd012 I might follow this as a basic guide. Now what about the 60 degree cuts? My chop saw will set from 0 to 45 on either side. What do I do to get the 60? Set it on 30 and flip the board over? Link to comment Share on other sites More sharing options...
Bob White Posted May 8, 2008 Report Share Posted May 8, 2008 Originally posted by AHI Look at the second picture in this link. http://www.creativehomeowner.com/index. ... d=chyrd012 I might follow this as a basic guide. Now what about the 60 degree cuts? My chop saw will set from 0 to 45 on either side. What do I do to get the 60? Set it on 30 and flip the board over? skll saw? Link to comment Share on other sites More sharing options...
ozofprev Posted May 8, 2008 Report Share Posted May 8, 2008 I built this onto the back of my house in Rochester, but had a nice compound miter. Without the right tools, things often look like they were built without the right tools. Image Insert: 18.1 KB Link to comment Share on other sites More sharing options...
Brian G Posted May 9, 2008 Report Share Posted May 9, 2008 Originally posted by AHI Now what about the 60 degree cuts? My chop saw will set from 0 to 45 on either side. What do I do to get the 60? Set it on 30 and flip the board over? I haven't tried that myself, but I would think you'll be setting it at 15° and figuring out how to lay the board up right to get the cut you need. 30° on one end; 60° on the other. Both are 15° from a simple 45° cut. You might goof up one or two getting things right, but those will be short pieces. Heck, grab a short piece of 2x and try it. Brian G. Then Again, I'm Probably Rusty as an Old Fish Hook About Now [] Link to comment Share on other sites More sharing options...
Jim Katen Posted May 9, 2008 Report Share Posted May 9, 2008 Originally posted by AHI Look at the second picture in this link. http://www.creativehomeowner.com/index. ... d=chyrd012 I might follow this as a basic guide. Now what about the 60 degree cuts? My chop saw will set from 0 to 45 on either side. What do I do to get the 60? Set it on 30 and flip the board over? What is it with you people and your chop saws? Get two 12" long 1x4s. Nail one on top of the other at 60 degrees to make a "T" with a 60-degree-slanted top. Use this jig to guide a skilsaw when making the cuts. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
John Dirks Jr Posted May 9, 2008 Author Report Share Posted May 9, 2008 Originally posted by Jim Katen Originally posted by AHI Look at the second picture in this link. http://www.creativehomeowner.com/index. ... d=chyrd012 I might follow this as a basic guide. Now what about the 60 degree cuts? My chop saw will set from 0 to 45 on either side. What do I do to get the 60? Set it on 30 and flip the board over? What is it with you people and your chop saws? Get two 12" long 1x4s. Nail one on top of the other at 60 degrees to make a "T" with a 60-degree-slanted top. Use this jig to guide a skilsaw when making the cuts. - Jim Katen, Oregon That's a good idea. Link to comment Share on other sites More sharing options...
randynavarro Posted May 9, 2008 Report Share Posted May 9, 2008 I still say pavers will look better and last forever. No maintenance. Probably cheaper than pressure treated wood, too. Link to comment Share on other sites More sharing options...
Tom Raymond Posted May 14, 2008 Report Share Posted May 14, 2008 Originally posted by randynavarro I still say pavers will look better and last forever. No maintenance. Probably cheaper than pressure treated wood, too. Only if you don't count the Chiropractor's bill[] Tom Link to comment Share on other sites More sharing options...
