What does it cost to remove vermiculite from an attic by someone who is asbestos competent and licensed to do such a thing?
I have priced asbestos pipe insulation and floor tile removal but not vermic.
You might want to have that tested for asbestos before you start looking for quotes for removal. Just because it is vermiculite does not necessarily mean that it does contain asbestos, only that it could.
Have no clue about removal costs.
In Portland, OR, it's about $5 - $8 per square foot.
See http://www.epa.gov/asbestos/pubs/insula ... chure2.pdf .
In particular...
Currently, there are specific technical issues
involving vermiculite sampling that can complicate
testing for the presence of asbestos fibers and
interpreting the risk from exposure. EPA and
ATSDR are not recommending at this time that
homeowners have vermiculite attic insulation tested
for asbestos. As testing techniques are refined,
EPA and ATSDR will provide information to the
public on the benefits of testing that produce more
definitive and accurate test results.
I believe the problem is that testing can tell that there is asbestos present, but it cannot reliably determine that it is not. Some samples may not show asbestos but it might still be present in other areas or layers. My understanding is that it is best to just assume that it does and take the appropriate precautions.
Jim...is that price per square foot or cubic foot?
According to my notes, it's per square foot from an attic. The guy that I was talking to said that the price varied from about $5 to about $8 depending on how deep it was and on how much of a pain in the butt it was to work in the attic; tall attics were cheaper than little, short attics that you have to crawl through. He also said that they can't use vacuum trucks anymore. They have to scoop it out by hand.
Thanks for that publication. I guess that it would make sense that a false negative for asbestos would be highly likely.
Time to modify my boiler...
We just discussed this recently. www.inspectorsjournal.com/forum/topic.asp?TOPIC_ID=5379
I talked to several locals today and the loosy goosie ballparky quotes were in the $4 to $7 per sq. ft. $500 to $1,500 minimum.
One guy told me without any specifics between $500 and $10,000.
Now, that is one helluva ballpark! Does he work for the government?
