Doug welborn Posted April 28, 2008 Report Posted April 28, 2008 A friend of mine has hardwood floors In a house that 4 years old and In the hall there Is a spot that pops when you step on It.The floor Is on a slab,any Ideas on how to fix It so the foor doesn't pop?
charlieb Posted April 28, 2008 Report Posted April 28, 2008 They make adhesive/filler kits for this. Call a real floor covering supply house. Where the installers go for tools. There are a couple of types. The epoxy is costly as you need to buy a gun. There are kits that use a syringe.
hausdok Posted April 28, 2008 Report Posted April 28, 2008 If it's a floating slab and they didn't leave enough room at the perimeter to allow for expansion the sides will butt against the base of the wall and raise the center. Remove the baseboards and trim the edges to allow more room. It should lie flat. OT - OF!!! M.
kurt Posted April 28, 2008 Report Posted April 28, 2008 Before anyone starts gunning goo into the floor, find out the floor type. Most likely, it's what Mike said, but make sure. If you glue down spots in the floor, it will royally screw up everything else.
charlieb Posted May 1, 2008 Report Posted May 1, 2008 Down south when we talk about hardwood on concrete it's an prefinished engineered wood floor. "A spot" is also a clue. It's not hard to tell wood from POS paper floating floors. Pump the goo
charlieb Posted May 1, 2008 Report Posted May 1, 2008 Originally posted by hausdok If it's a floating slab and they didn't leave enough room at the perimeter to allow for expansion the sides will butt against the base of the wall and raise the center. Remove the baseboards and trim the edges to allow more room. It should lie flat. OT - OF!!! M. I'm not absolutely sure but the only area in the south where a floating slab is used is in FL. Monolithic slabs down here.
hausdok Posted May 1, 2008 Report Posted May 1, 2008 Originally posted by charlieb Down south when we talk about hardwood on concrete it's an prefinished engineered wood floor. "A spot" is also a clue. It's not hard to tell wood from POS paper floating floors. Pump the goo Except there are also engineered wood floors that are the floating type and aren't paper. It's been a while, but I think Bruce is one brand. OT - OF!!! M.
Scottpat Posted May 1, 2008 Report Posted May 1, 2008 I have glue down Bruce wood floors in my home. I also have the infamous "Pop" in one spot. This is the result of the slab not be level and not being prepped properly by the floor installer before the wood floor was installed. The slab has a small dip and does not allow the glue to adhere properly to the wood plank in this location. So as you walk across it and push it down it sticks for a moment to the glue and then pops back up. Floating floors do not use glue and will "bow" if they have not been given room for expansion along the edges. Pergo is a big name in floating floors. Glue down engineered wood floors are the most common on slab construction and if they are done properly they are just fine and look just like a "real" nail down wood floor.
charlieb Posted May 1, 2008 Report Posted May 1, 2008 Originally posted by Scottpat I have glue down Bruce wood floors in my home. I also have the infamous "Pop" in one spot. This is the result of the slab not be level and not being prepped properly by the floor installer before the wood floor was installed. The slab has a small dip and does not allow the glue to adhere properly to the wood plank in this location. So as you walk across it and push it down it sticks for a moment to the glue and then pops back up. Floating floors do not use glue and will "bow" if they have not been given room for expansion along the edges. Pergo is a big name in floating floors. Glue down engineered wood floors are the most common on slab construction and if they are done properly they are just fine and look just like a "real" nail down wood floor. The goo also acts as a void filler and adhesive. Large spots require more than one hole to be drilled. The extra hole will act as a vent. Small dowels are driven into the holes and set. Top it off with a color match putty and call it done.
mayeaux1 Posted February 18, 2010 Report Posted February 18, 2010 What would be considered to be a normal amount of "hollow" spots under a glue down wood floor application? The floors were leveled with "patch", the floor product was acclimated to the environment for three days prior to install, BST was the glue used. 1500 s/f were installed. There is no movement anywhere in the floor, but hollow spots can be heard near the walls in about 25 locations, if you tap on them or bounce a ball.
