are6mr2 Posted April 22, 2008 Report Share Posted April 22, 2008 Hi all my company uses Omniform 5.0 form filler for our reports and I figured out how to attach images but when I go to email them they do not show up. Do anyone here use Omniform 5.0 and know how to attach and email pictures with it? I figure its a long shot but just seeing. Thanks Link to comment Share on other sites More sharing options...
tbowker Posted April 22, 2008 Report Share Posted April 22, 2008 Hi..I use Omniform. When I email the report to the client, i print it to a PDF format and email it to them as a file attachment. If you don't have the means of printing to a PDF format, google pdfFactory, they have a free program to do so. Link to comment Share on other sites More sharing options...
are6mr2 Posted April 24, 2008 Author Report Share Posted April 24, 2008 Thanks. I do print my reports to a PDF file then email but my pictures are too large in size or there are too many to attach directly to the email. So I was wondering how you do it? Thanks. Link to comment Share on other sites More sharing options...
tbowker Posted April 25, 2008 Report Share Posted April 25, 2008 The only way that i can think of in your case would be to go and start a new page. First start omniform 5.0, then you should have a window come up that says "form assistant". Click on "create a new blank form" and click finish. Go to the tab that says "form design" on the top left of the page, then look for a graphic fill on the left hand side, click on it and then highlight an area on the blank page that you want your photo to go. Mine i fit six photo's per page. When you are done, click on "filler form" on the top left tab. Next step is to put your cursor over the field in yellow, a screen will pop up and say "fill graphic", press "source" then look for you pics. then below that is a button to "scale to fit" That should compress your pics and make them smaller. Then print them as a PDF, like i said before, i like pdfFactory, because it compresses better than the other PDF printers out there. Hopefully this helped. Link to comment Share on other sites More sharing options...
are6mr2 Posted April 29, 2008 Author Report Share Posted April 29, 2008 Thanks so much Im going to try that I was worried how it would print out in the PDF file but from what you are saying it should not be a problem. After your convert the omniform to a PDF file then email it do the pictures show up in Adobe when the recipant open the PDF file? Link to comment Share on other sites More sharing options...
tbowker Posted April 30, 2008 Report Share Posted April 30, 2008 Mine do. At first i used a different pdf converter, when there were pictures attached, the files were extremely big. I switched to pdffactory, and this made them smaller so i could email all the pages together. when you print to pdf, remember to save it to your documents, then look at it before you send it to your client. Link to comment Share on other sites More sharing options...
