Bryan Posted April 19, 2008 Report Share Posted April 19, 2008 I see wood trim and siding installed with out the proper clearance to flashing, concrete and earth. I know it's wrong and there should be clearance to prevent wicking of moisture which will lead to rot and detereration. It is rare anyone would remove all the trim and siding to repair the issue, so what should the recommendation be to the client? Bryan Link to comment Share on other sites More sharing options...
Jim Katen Posted April 19, 2008 Report Share Posted April 19, 2008 Originally posted by Bryan I see wood trim and siding installed with out the proper clearance to flashing, concrete and earth. I know it's wrong and there should be clearance to prevent wicking of moisture which will lead to rot and detereration. It is rare anyone would remove all the trim and siding to repair the issue, so what should the recommendation be to the client? Bryan Why would you consider making your recommendations contingent on whether or not someone is likely to carry them out? When I see something that I think is a problem, I just tell folks what's wrong, why I think it's important, and what I think they outght to do to fix it. Then I let them decide what is and isn't worth fixing. If you try to make that decision for them, you're making the job much harder than it needs to be. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
inspect4u Posted April 19, 2008 Report Share Posted April 19, 2008 "Nuff said." Mike M Link to comment Share on other sites More sharing options...
