Hey guys,
Has anyone ever seen this before? It was the first for me. It is two 50 gal water heaters hooked in series, cold coming into one and sending hot out to the other one and the other one feeding the house. Looks like a waste of money to me, cost of running two water heaters to basically get a 100 gal capacity.
Mike M
Image Insert:
39.38 KB
I see them in series and parallel. Tried both ways. Each way has it's supporters and detractors. Each side believes fervently that the "other" way is horribly wrong.
From what I've seen, and I've seen them a fair amount, I don't think it makes all that big a difference whether it's series of parallel.
Standard fare here in the big city on larger homes, most of them stuck up in the attic.
I kind of prefer the series route, but I can see the advantage of the parallel method if equipped with isolator valves.
I have two electric ones in series. The first one stays off unless we have company. It serves as a storage tank when off that gains some heat from the garage to warm up the cold well water, especially in the summer.
I see no use for parallel operation, cold water entering both tanks as the hot is used makes no sense at all for residential.
