Jim Katen Posted April 16, 2008 Report Posted April 16, 2008 I have not seen this toilet. The owner says that the toilet flushes properly and that the water level in the bowl is at the normal height 5 minutes after it's been flushed. However, when she comes back an hour later, the level of water has dropped to a mere puddle. I can't recall having seen this before. Does anyone know what's going on? - Jim Katen, Oregon
Jim Katen Posted April 16, 2008 Author Report Posted April 16, 2008 Originally posted by Brandon Whitmore Does she have a dog?[:-slaphap It's funny, but I already asked. She has a Yorkie that can't reach the seat. The damn dog is smaller than the volume of water that goes missing. - Jim Katen, Oregon
Brandon Whitmore Posted April 16, 2008 Report Posted April 16, 2008 Try this one--- there is a slight leak in the flapper. The tank will fill the bowl to where it has enough head pressure to siphon and suck the bowl down. The tank will keep re- filling, just not noticeably.
ozofprev Posted April 16, 2008 Report Posted April 16, 2008 Jim, From HERE (#7) I found: The toilet may be partially clogged. The clog can actually cause a siphon and pull water from the bowl. The other possibility is more severe. There can actually be a crack or small defect in the colon of the toilet. This is the channel that water passes through to get to the drain pipe. A colon crack or defect means it is time for a new toilet. How old is the toilet? HEREis why I ask.
hausdok Posted April 16, 2008 Report Posted April 16, 2008 Hi, Yeah, a hairline crack had been my guess. OT - OF!!! M.
exploreparadise2 Posted April 16, 2008 Report Posted April 16, 2008 I never knew that the channel in the toilet that the waste flows through is called a colon. How appropriate.
fqp25 Posted April 16, 2008 Report Posted April 16, 2008 A lot of things could happen to cause the toilet to siphon out. Back when I did service calls a lot of times there was something stuck in the trapway. Such as wad of TP, or feminine hygiene product. Might recommend the owner to purchase a Rigid K-3 Toilet Auger. $25 or so at HD. And try to see if anything gets stuck on the end of it, such as paper. (I'm sure everybody has a plunger, but an auger is handy as well, and I would never recommend anything else but Rigid K-3 with a bulb head. It's great for cleaning toilet trap ways.) Blockage in their main drain lines could cause an extra siphoning, if not vented properly/adequately Inadequate venting could also cause this. There maybe just enough venting for that toilet when it's flushed, but if there is a surge in the main sewer line around their house, this could cause traps in that house to siphon out. Never rule out the phenomenon of the wind playing a role. ( I had always doubted that theory, until a few years ago, when it was the only logical explanation, but that is a long, long story) Frank
