John Dirks Jr Posted April 12, 2008 Report Posted April 12, 2008 Would you consider this solid evidence of draft spillage? It's a mirror being held next to the draft diverter at the water heater. You can see the fogging on the mirror. Image Insert: 76.1 KBe
Bain Posted April 12, 2008 Report Posted April 12, 2008 Did you check the flue pipe with a lighter? The mirror might fog up, even if the water heater was drafting properly. Also, don't forget that there's always a little spillage for a few seconds after the burners ignite.
Neal Lewis Posted April 12, 2008 Report Posted April 12, 2008 Maybe if you circle the fogging and write a caption, otherwise it doesn't look like anything. Are you trying to determine if it's backdrafting or just trying to document it?
John Dirks Jr Posted April 12, 2008 Author Report Posted April 12, 2008 I didn't check with a lighter. This picture was taken long after startup. I was trying to determine if it was backdrafting. Heres where it enters the chimney next to the flue from the induced draft furnace. Is there anything wrong here? The furnace was not running when the mirror picture was taken. Image Insert: 112.78 KB
Jim Katen Posted April 13, 2008 Report Posted April 13, 2008 Originally posted by AHI I didn't check with a lighter. This picture was taken long after startup. I was trying to determine if it was backdrafting. Heres where it enters the chimney next to the flue from the induced draft furnace. Is there anything wrong here? The furnace was not running when the mirror picture was taken. I'd call that backdrafting. What's with the weird plumbing fitting in the foreground of the picture. It looks like a knurled female garden hose fitting. - Jim Katen, Oregon
Les Posted April 13, 2008 Report Posted April 13, 2008 I am supposed to know what I'm looing at and I can't call that backdrafting. I don't like the metal tape on the flue and I'd be quite suspect about the flue to chimney connection. The weird fitting likely is from a non-potable water device and would not have any NSF or ul approval. skilled homeowner installation
Neal Lewis Posted April 13, 2008 Report Posted April 13, 2008 I put my hand in front of the draft hood and feel for the heat backing up, and the draft hood will be hot. I don't use a mirror. The exhaust vent/flue for the smaller appliance should be located above the larger one, but it may not affect the drafting. That looks like an older house, with the clay tile on the left. What's the condition of the chimney flue?
John Dirks Jr Posted April 13, 2008 Author Report Posted April 13, 2008 The clay lined masonry chimney flue was in good condition. The still picture doesn't really document the spillage as well as seeing it happen. The fogged area was continually moving and and fluctuating in size as it danced across the surface of the mirror. The still picture just shows one exact point in time. As I watched it, it was a live, continuing and constantly moving event. Maybe the pipe is shoved too far into the chimney and causing partial blocking.
inspect4u Posted April 13, 2008 Report Posted April 13, 2008 Originally posted by AHI Heres where it enters the chimney next to the flue from the induced draft furnace. Is there anything wrong here? Section G2426.5.6.2 states "If two or more openings are provided into one chimney flue, they shall be at different levels." Mike M
John Dirks Jr Posted April 13, 2008 Author Report Posted April 13, 2008 The plumbers and HVAC techs are being recommended for other reason anyway so I did include these items in the report and recommended that they be checked.
qhinspect Posted April 13, 2008 Report Posted April 13, 2008 Tell me if I'm wrong, but I thought the match test is the recommended test per manufacturer. I know I read it and I have been thinking I read it from more than one manufacturer (Like the 2 by 4 test for garage door opener reverse safety). I'm going to look into this tonight to make sure. Update: I looked up a couple of manufacturers and it's written to use a match (or lighter) to determine if a good draft exist. Do what you want but I would use this method since you have written proof on how to check for draft so if somebody questions it (like the seller, listing agent or the worst, a lawyer) then you have the manufacturer to back you up.[^]
