Does this brick chimney (with issues of its own) location in relation to the furnace vent represent "a vertical wall or similar obstruction" as in G2427.6.3 #2 of the 2006 IRC and should be terminated two feet above the chimney? I told my clients that it was short but I wasn't sure how much. Thanks for any replies. Ed
Image Insert:
342.2 KB
Hi,
Well, without looking it up, I believe the requirement is two feet above any vertical sidewall within 8 ft., but I'm not so certain that a chimney that's only about 2ft. on a side will make that much difference, but it will cost very little to add another 3-4ft. to that vent and install some guy wires. That's what I'd write.
OT - OF!!!
M.
You betcha.
  • 5 weeks later...
Image Insert:
342.2 KB
Definitely an issue. Violates the 10-2-3 rule.
Based on memory the requirement for a chimney is the 10-2-3 rule. For a B vent, there is no 10-2-3 rule. The requirement is based on the slope of the roof (min. 12"). The 2' above the roof line within 10' applies when there is a sidewall within 8' horizontal feet of a sidewall.
I am still not fully convinced that the B vent needs to be extended.....
I am curious as to why there is a requirement to go 2' above any point within 8' horizontally of a sidewall, when there is only a 12" requirement elsewhhere. The only thing I can think of is that there would be a chance of venting back through an eave vent or window??
Anyone have an idea or answer?
Originally posted by Brandon Whitmore
. . . I am curious as to why there is a requirement to go 2' above any point within 8' horizontally of a sidewall, when there is only a 12" requirement elsewhhere. The only thing I can think of is that there would be a chance of venting back through an eave vent or window??
I believe that it's related to turbulence. When the wind blows against a wall, it creates turbulence that can interfere with the drafting of a B-vent.
I suspect that the same thing would happen with the chimney in the OP.
Is the chimney 2' taller than anything within 10' of it? Doesn't look like there is a 24" difference b/w that and the metal vent next to it.
