Inspected a home built in 1874 today. Most of the exterior doors had the paint cracking in the small 2x2 square type of pattern.
The realtor said that a home inspector once told her that this was a sign of lead paint. I replied that although I would think lead paint had been used in the home at some point the cracking pattern would most likely be do to lack of a primer base coat, improper exterior paint and weathering.
Truth or urban legend on this pattern and lead paint?
Thanks,
Sounds like incompatible layers. Someone repainted the doors without sanding them down and re-priming them. The top layer is reacting with whatever is underneath. Lead paint tends to curl up as it peels off.
OT - OF!!!
M.
