New construction inspection.
The builder installed unfaced batt insulation in the rafter cavities in the knee wall area. The batt insulation is then covered over with a white plastic type membrane-- pictures will follow.
I am curious as to how to be sure there is the required gap between the insulation and roof sheathing. I already know they did this wrong , at least in some areas---- several of the eave vents screens are blocked by the insulation as visible at the exterior of the home.
Also, what is the best way to air seal openings / gaps in the plastic membrane, such as where the B vent and plumbing vent pipes penetrate?
Image Insert:
2.85 KB
Image Insert:
4.21 KB
Image Insert:
3.95 KB
Is it a permeable membrane or just plastic? I'd use Airlok - latex mastic.
Mike,
I usually just see the clear or whitish plastic, but in this case it was a little thicker-- more permeable looking though... more like a weather resistive barrier look to it.
Worst case scenario with the air leaks, what would you expect to occur?
