JEuriech Posted March 12, 2008 Report Posted March 12, 2008 Concrete Questions If there was no expansion joint between the back of a house and a concrete patio slab, would this be called out as a defect? (only one side/face of the slab touching the house) On a new house, if three sides of the patio slab was touching the house with no expansion joint, I assume this would be a defect because there is no room for expansion. (damage may occur) If it was a five year old house with no signs of cracking, would you still call it out as a defect? In the summertime, how much will concrete expand, say for a 20' section of driveway? Are we talking like a 1/4" or something a lot more? Thanks Jeff Euriech Peoria Arizona
Scottpat Posted March 12, 2008 Report Posted March 12, 2008 Both were most likely poured at the same time. You will see this done with garages, the front porch and patios. It is a time saver and that is about all. Concrete is at it's largest point when it is first poured. It shrinks as it cures. As for expanding when it is hot, I don't know how much but it would be a very small amount.
ozofprev Posted March 13, 2008 Report Posted March 13, 2008 A 10m length undergoing a 50 degree centigrade temperature increase expands about 5mm. http://www.cement.ca/cement.nsf/0/74270 ... ent&Click=
chrisprickett Posted March 13, 2008 Report Posted March 13, 2008 Jeff, It's commonly done out here when there's a monolithic pour. You'll likley see some hairline cracking, but it's not s a structural isse.
