Konrad Posted April 23, 2004 Report Posted April 23, 2004 Why is it that copper roof sheathing will develop a patina and eventually turn black and then green, but not copper piping inside buildings? At first I thought maybe it's because of UV, but the copper roofs I see installed all discolor uniformly regardless of their orientation to north/south. So what's the difference between inside and outside? Copper is copper, right?
Brian G Posted April 23, 2004 Report Posted April 23, 2004 Originally posted by Konrad Why is it that copper roof sheathing will develop a patina and eventually turn black and then green, but not copper piping inside buildings? So what's the difference between inside and outside? Rain, perhaps? Rain + air (exposure) = oxidation? Water sealed in a pipe - air (exposure) = no oxidation? Can you tell I'm guessing? Brian G.
Jim Morrison Posted April 23, 2004 Report Posted April 23, 2004 Brian is correct, water is the catalyst you need for the chemical reaction that oxidizes copper but I'm not the Jim who can explain it. I believe you are looking for the Woodshed Wizard of the West, Mr. Jim Katen.
Norm Posted April 23, 2004 Report Posted April 23, 2004 Oxidation is the key. Water on the surface of the copper is necessary in order to cause this chemical reaction. Other than the relative humidity in contact with the outside surface of copper water piping within a dwelling there isn't a sufficient water source for oxidation to take place. I remember this from inorganic chemistry 101 about 40 years ago. Or maybe it's 45 years in which case I don't remember sh-t. NORM SAGE
hausdok Posted April 23, 2004 Report Posted April 23, 2004 I think it has to do with the acids in the exterior air that are there as a result of combustion processes. The copper pipe will turn the same green wherever the acid from soldering flux gets on it and the air around us is heavy with hydrocarbons that contain various acidic compounds. ONE TEAM - ONE FIGHT!!! Mike
Jim Morrison Posted April 23, 2004 Report Posted April 23, 2004 Mike, I can't imagine there are appreciably more airborne acids outside than in. I'd expect the gaseous makeup of air to be roughly the same in a person's basement as they are on the outside, excepting specific local conditions like a belching boiler, etc.
Neal Lewis Posted April 24, 2004 Report Posted April 24, 2004 So how long does it take for the exterior copper to turn green? Fifty years?
hausdok Posted April 24, 2004 Report Posted April 24, 2004 Hi Jim, I don't mean the gaseous makeup of air, I'm talking about the man-made contaminants that we and nature dump into the outside air that we aren't exposed to indoors. We burn coal and oil for electricity which returns to the surface in acid rain and affects the outdoor environment a great deal. Then you have tannic acid from trees and oxalic acid from algae and mosses, plus all of the hydrocarbons from automobile exhaust, none of which you have in the atmosphere of your home. Have you ever noticed that a raindrop or a snowflake tastes bitter? We see copper pipe that is normally less than 100 years old, but other copper inside of older buildings, such as hinges, does develop a green patina - it just takes a lot longer indoors than outside. I think oxidation outside is more prevalent because it's sped up by contaminants in the air that mix with rain and disperse it through the exterior atmosphere more than inside. The Katenizer can probably nail it. ONE TEAM - ONE FIGHT!!! Mike
kurt Posted April 24, 2004 Report Posted April 24, 2004 Ammonia will give copper the most amazing deep green patina, and not the "fluffy" patina; it's the deep patina that doesn't rub off on your clothes. Pouring the ammonia on the copper won't due it; you have to "fume" the copper w/ the ammonia gas. It takes several days, but it is a nice way to quickly "color" copper.
RobC Posted April 24, 2004 Report Posted April 24, 2004 Here is a bit of information on the process. http://www.copper.org/resources/propert ... green.html
Jerry Simon Posted April 24, 2004 Report Posted April 24, 2004 Just saw some real shiny copper inside a home and wondered the exact same thing...why still so shiny? How weird is that? Thanks for the info. Also just paid a bill of $54.99 with...get this, check #5499...can you stand it! Also, if you didn't just hit the wrong key, it's reglet, not riglet.
Brian G Posted April 24, 2004 Report Posted April 24, 2004 Originally posted by Jerry Simon Just saw some real shiny copper inside a home and wondered the exact same thing...why still so shiny? How weird is that? Also just paid a bill of $54.99 with...get this, check #5499...can you stand it! Jerry, bad news old boy. That means you're going to die a slow, horrible death in the near future. There's only one way out of it, which I'll be happy to share with you. Just send me $10,000 before it's too late, and I'll take care of it. [:-mischievous] Brian G. Semi-Professional Curse Lifter [:-witch]
Jim Katen Posted April 24, 2004 Report Posted April 24, 2004 Originally posted by Konrad Why is it that copper roof sheathing will develop a patina and eventually turn black and then green, but not copper piping inside buildings? At first I thought maybe it's because of UV, but the copper roofs I see installed all discolor uniformly regardless of their orientation to north/south. So what's the difference between inside and outside? Copper is copper, right? Actually, no. The copper products we use are alloys. Tubing and roofing are different alloys, I'm sure. However, this probably doesn't make much difference to your question. I pretty much agree with everyone else. The roof is exposed to all sorts of contaminants that the stuff inside and under the house never sees. - Jim Katen, Oregon
Rob Amaral Posted April 24, 2004 Report Posted April 24, 2004 Professional Roofing magazine had a cool article on a similar issue this past month. Check it out. (NRCA's rag). I've been driving around looking for these evidences. (Why does exterior copper sometimes corrode and sometimes not...that was the drift of the article). Acid rain was the cause on the East Coast... check it out. R
RobC Posted April 25, 2004 Report Posted April 25, 2004 Maybe the article I posted earlier would answer ALL your questions, just maybe, I don't know............well maybe .........well how about checking it out .....maybe. http://www.copper.org/resources/propert ... green.html Not suffering from attention defecit deprevation ...or maybe
