Joe Tedesco Posted March 4, 2008 Report Share Posted March 4, 2008 Just an update for your files related to the equipment: BASEBOARD HEATERS (KLDR) This listing covers space heaters of the portable and permanently mounted types intended to be positioned or installed on or in the wall at the baseboard level, or on the floor. Baseboard heaters have been investigated and found to incorporate suitable safeguards against establishment of fire hazards that might result from contact with draperies, furniture, carpeting, bedding and the like; however, discoloration or scorching (but no glowing embers or flaming) may result on adjacent materials. Heaters, other than those marked to indicate that they are not for residential use, have been investigated to determine that the accessible surface temperatures are low enough to reduce the likelihood of burns from accidental contact. Electrical cords, drapes, and other furnishings should be kept away from baseboard heaters. To reduce the likelihood of cords contacting the heater, the heater is not to be located beneath electrical receptacles. Listings of receptacle accessories for use with an individual manufacturerââ¬Ëââ¬Ës baseboard heaters are included under the category ââ¬â¢Ã¢â¬â¢ Baseboard Heater Accessories² (KLQZ). Baseboard mounted equipment consists of two types: Complete units intended for individual mounting in specific locations, and complete systems, which include accessories to enable the heating units to be interconnected around the perimeter of a room. Listings for accessories appear under Baseboard Heater Accessories. With reference to these systems, each manufacturer is required to furnish detailed instructions covering the assembly of the basic units and accessories, and indicating the method in which ground continuity is intended to be maintained between adjacent sections. Electrical fittings are provided with each heater of a system to insure ground continuity between adjacent units and to protect interconnecting wiring, unless investigation shows that standard fittings which are available in the field will accomplish the same result. A system which is factory furnished with all interconnecting wiring, fittings, raceways, etc., to complete the installation is considered suitable for connection to a single outlet branch circuit. For additional information, see Electrical Equipment for Use in Ordinary Locations (AALZ) and Heating, Cooling, Ventilating and Cooking Equipment (AAHC). The basic standard used to investigate products in this category is UL 1042, ââ¬Ëââ¬ËElectric Baseboard Heating Equipmentââ¬â¢Ã¢â¬â¢. The Listing Mark of Underwriters Laboratories Inc. on the product is the only method provided by UL to identify products manufactured under its Listing and Follow-Up Service. The Listing Mark for these products includes the UL symbol (as illustrated in the Introduction of this Directory) together with the word ²LISTED,² a control number, and the product name- ââ¬Ëââ¬ËElectric Baseboard Heaterââ¬â¢Ã¢â¬â¢ . Baseboard Heater Accessories (KLQZ) This category covers accessories intended to be used in conjunction with individual manufacturer²s Listed baseboard heater systems (see Baseboard Heaters). Accessories include wiring components for interconnection of individual units, corner, blank and filler sections, to facilitate perimeter installation, temperature regulating components and other general and special use receptacle and switch components to be mounted in line with baseboard heater installations. Attachment plug receptacle sections of baseboard heating systems provided for installation along with the other components of baseboard air heating systems, are intended to be supplied by means of conventional wiring methods, from separate branch circuits, not interconnected with the heating system. Combination transfer switch-receptacle sections of baseboard heating systems which permit use of either the heating system by itself, or a separate room air conditioner by itself, are intended to be connected to a single branch circuit of appropriate size. For additional information, see Electrical Equipment for Use in Ordinary Locations (AALZ) and Heating, Cooling, Ventilating and Cooking Equipment (AAHC). The basic standard used to investigate products in this category is UL 1042, ââ¬Ëââ¬ËElectric Baseboard Heating Equipmentââ¬â¢Ã¢â¬â¢. The Listing Mark of Underwriters Laboratories Inc. on the product is the only method provided by UL to identify products manufactured under its Listing and Follow-Up Service. The Listing Mark for these products includes the UL symbol (as illustrated in the Introduction of this Directory) together with the word ²LISTED,² a control number, and the product name ââ¬Ëââ¬ËBaseboard Heater Accessoryââ¬â¢Ã¢â¬â¢ . Link to comment Share on other sites More sharing options...
Jeff Remas Posted March 5, 2008 Report Share Posted March 5, 2008 Joe when did the code change not allowing receptacles above baseboard heaters? I see this in a lot of homes from the 70's. It is more of an issue when a cord goes inside and touches an element. What age group of heaters are you referring to? Link to comment Share on other sites More sharing options...
Jim Katen Posted March 5, 2008 Report Share Posted March 5, 2008 Originally posted by Jeff Remas Joe when did the code change not allowing receptacles above baseboard heaters? I see this in a lot of homes from the 70's. It is more of an issue when a cord goes inside and touches an element. What age group of heaters are you referring to? The NEC doesn't and never has prohibited receptacles above baseboard heaters. The baseboard heater manufacturer's prohibit it. I don't know when they started to disallow it. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Neal Lewis Posted March 5, 2008 Report Share Posted March 5, 2008 There is a Fine Print Note that says "Listed baseboard heaters include instructions that may not permit their installation below receptacle outlets." At least in the 1996 NEC version. Link to comment Share on other sites More sharing options...
Jim Katen Posted March 6, 2008 Report Share Posted March 6, 2008 Originally posted by Neal Lewis There is a Fine Print Note that says "Listed baseboard heaters include instructions that may not permit their installation below receptacle outlets." At least in the 1996 NEC version. Yes. That first appeared in the 1990 edition. FPNs are just explanatory. They're aren't enforceable parts of the code. That note means, "Dude, the NEC doesn't prohibit receptacles over baseboard heaters, but the manufacturer might." - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
