John Dirks Jr Posted March 1, 2008 Report Posted March 1, 2008 How does lot grade play into the role of the location of a sump pump? If you have a significant slant to the grade, is there a specific reason why it should be located on either side? What are some other factors in exercising best practice when deciding the location of a sump pump?
Neal Lewis Posted March 1, 2008 Report Posted March 1, 2008 Don't place it directly in front of the panel box!
Steven Hockstein Posted March 1, 2008 Report Posted March 1, 2008 Exterior grade and where the pump(s) discharges to the exterior definitely affect the pit location(s). Another factor is where does it least impact the design and ease of access for servicing and inspecting, especially if a finished basement is planned. In large homes we often show more than a single pit. If there is more than one level in the basement, for obvious reasons, the lowest floor slab has to include a sump pit.
Jim Katen Posted March 1, 2008 Report Posted March 1, 2008 Originally posted by AHI How does lot grade play into the role of the location of a sump pump? If you have a significant slant to the grade, is there a specific reason why it should be located on either side? What are some other factors in exercising best practice when deciding the location of a sump pump? In my area, it doesn't make a whole lot of difference. The sump pump only drains a radius of about 3-5 feet around it. Without a system of drain tiles, sump pumps are nearly useless. - Jim Katen, Oregon
ozofprev Posted March 2, 2008 Report Posted March 2, 2008 It's all about the drain tiles. Sump location is quite flexible. Keep in mind that the pump will run continuously in a swamp - no matter its location.
