inspecmoore Posted February 26, 2008 Report Share Posted February 26, 2008 I understand that when gas logs are placed in a fireplace the damper should be equipped so that it cannot be closed. But I'm told that ventless gas log systems should have the dampler closed. Is this true, and if so, is there a way to tell the difference between a vented and ventless gas log system by looking? Thanks for your help. Link to comment Share on other sites More sharing options...
inspector57 Posted February 26, 2008 Report Share Posted February 26, 2008 There should be a name plate with model and serial number that you can find on the front of the unit. How old is the unit? Of course, I PERSONALLY would not want to suck on an exhaust pipe just to stay warm. Link to comment Share on other sites More sharing options...
inspecmoore Posted February 26, 2008 Author Report Share Posted February 26, 2008 The unit was installed just recently in an existing wood burning fireplace. Link to comment Share on other sites More sharing options...
Eric B Posted February 26, 2008 Report Share Posted February 26, 2008 Tim, If it's a true ventless unit, there will not be a damper. If someone is saying that a damper firebox can be used at ventless it's wrong. Ventless appliances use specific burners that would not be used in vented applications. All manufactured fireplaces should be used only as they were designed and tested for - no modifications. Does this help? Link to comment Share on other sites More sharing options...
msteger Posted February 26, 2008 Report Share Posted February 26, 2008 But how does one burn a fossil fuel without producing any byproduct exhaust? A 'Ventless fireplace' sounds like an oxymoron. Link to comment Share on other sites More sharing options...
hausdok Posted February 26, 2008 Report Share Posted February 26, 2008 Hi Matthew, The use a catalyst to eliminate the CO. It works, but these still produce a ton of moisture and dump particulate matter into the interior air. OT - OF!!! M. Link to comment Share on other sites More sharing options...
inspecmoore Posted February 27, 2008 Author Report Share Posted February 27, 2008 Originally posted by Eric B Tim, If it's a true ventless unit, there will not be a damper. If someone is saying that a damper firebox can be used at ventless it's wrong. Ventless appliances use specific burners that would not be used in vented applications. All manufactured fireplaces should be used only as they were designed and tested for - no modifications. Does this help? Eric, yes that helps. The Code Check 5th Edition says under "Fireplace with gas appliance": "Decorative log set requires damper blocked open" And "Unvented log heaters not in factory fireplace unless L&L." I was just a little unclear about what that actually required. Tim Link to comment Share on other sites More sharing options...
jon_ran Posted February 27, 2008 Report Share Posted February 27, 2008 Originally posted by msteger But how does one burn a fossil fuel without producing any byproduct exhaust? A 'Ventless fireplace' sounds like an oxymoron. We have to remember that carbon monoxide is an emission from incomplete combustion of the fossil fuel. True combustion should only produce carbon , hydrogen and oxygen (C and O combine to produce CO2 - carbon dioxide, H and O combine to create h2o- water). Pure combustion of natural gas and propane produces a blue flame, incomplete combustion produces yellow or orange flames. The hydrogen atoms are easiest to satisfy and will be greedy and be satisfied first by attaching themselves to an oxygen atom (2 hydrogens/1 oxygen) this will fill all of the atomic rings and satisfy all of the hydrogen atoms released, creating water. The carbon atoms left over because they were not all burned up will start grabbing the left over oxygen molecules trying to create co2, but being a friendly bunch, they do not want to be stingy and therefore share the oxygen atoms so that they can all get slightly satisfied, instead of simply gorging themselves until they are stuffed. Since the carbon was not completely, there will be an excess of carbon atoms and not all will be satisfied. The resulting molecules will be carbon with one oxygen (CO) and in severe cases, pure carbon (soot). CO2, and H2O from complete combustion are relatively harmless in low or normal concentrations. CO, on the other hand, is dangerous in low doses because our bodies will absorb it before oxygen even when oxygen is present. A vent less fireplace uses a catalyst plate (like the calytic converter in your car's exhaust) which increases the temperature of the flue cases to a point that the carbon atoms are more thoroughly burned up. This allows what little carbon that remains to fill itself with oxygen and become carbon dioxide. Regardless, I always highly recommend a CO detector in the home. Catalyst plates can and do get coated and need replacement over time. Link to comment Share on other sites More sharing options...
