Richie Rich Posted January 8, 2008 Report Share Posted January 8, 2008 Once again searching for information about a building here in texas. I've been grinding on this concrete for quite a while and am curious as to current day tolerances in the slab. For example over an 8' are the float to approximate level was about 5/8". Grinding in about 6' square area exceeded 1/2" and I'm now working on an area in the range of 5/8" grinding to approximate level within 3/16" in 10',(for floating wood floor). One room has a depression that will take at least 1/2" float (for the floating wood floor). And lastly one bay of the garage has a depression of 1/2" + in a corner. So what are current building standards for a poured concrete slab? P.s. The pex where it enters the slab is at grade - probably not a problem in north texas, but... Thanks for the information and great assist. Link to comment Share on other sites More sharing options...
hausdok Posted January 8, 2008 Report Share Posted January 8, 2008 Hi, This may sound like a dumb question, but why didn't you just float a level overlay of leveling compound or gypcrete on top of the slab? OT - OF!!! M. Link to comment Share on other sites More sharing options...
randynavarro Posted January 8, 2008 Report Share Posted January 8, 2008 I would suggest checking with the maker of your finish flooring product and grinding (or floating) to those tolerances. With the numbers you're describing, I wonder if anyone would even notice it on foot as it is now. Link to comment Share on other sites More sharing options...
MMustola Posted January 8, 2008 Report Share Posted January 8, 2008 The National Association of Home Builders "Residential Construction Performance Guidelines" states that concrete floors in living areas shall not have pits, depressions, or area of unevenness exceeding 3/8-inch in 32 inches. Now I know may of you think these standards are poor and are really slanted toward the builder but I don't think the IRC address how level the slab should be. Link to comment Share on other sites More sharing options...
Les Posted January 8, 2008 Report Share Posted January 8, 2008 Mark, you are right. But there is a difference between level and smooth. You and me both see level garage floors that pond water, get ice film, etc. Me? I want a smooth garage floor tilted at abt 1/2" in 12' toward the overhead door. Link to comment Share on other sites More sharing options...
chrisprickett Posted January 8, 2008 Report Share Posted January 8, 2008 Here are AZ applicable standards, FWIW... 1. Floors should not vary from flat more than 1/4" over a 10' area provided the deviation is gradual. Deviations, dips, or sags over short distances and easily visible to the eye may be considered unacceptable. 2. Floors should be level within 1/4" in any 12' run. Out here, we avoid running PEX through the slab. that's one of the advantages of PEX- because it's much cheaper than copper, you can run it in walls and the attic, thus avoiding supply piping leaks. In the applicationswhen it is under slab (it see it used as a conduit for icemaker lines and for island plumbing) it should be wrapped with with a foam type material like sill seal. Direct contact w/ the concrete can cause stress due to expansion/contraction. We don't worry too much about freezing in these parts. Link to comment Share on other sites More sharing options...
