Originally posted by Chris Bernhardt
Are there any flashing methods or products that can be used without having the electrical service disconnected to have a pipe jack installed?
What do you recommend when you find this condition?
Chris, Oregon
If I'm doing the roofing job:
* Buy two Oatey No Calk roof flashings.
* Slit the first one from the top of the hole to the top of the flashing.
* Slip it around the mast from the downhill side of the roof.
* Slit the second one from the bottom of the hole to the bottom of the flashing.
* Slip it around the mast from the uphill side of the roof.
* Stich the exposed portion of the seam together with metal roofing screws (the kind with built in cup washers and neoprene rings).
If I'm writing a report:
"Install proper flashing at the electrical mast where it goes through the roof."
Originally posted by Eric B
Pipe jack? Not a term I've heard before.
A pipe jack is the pre-manufactured flashing that fits around a plumbing vent pipe. It consists of a metal base flashing and a neoprene neck.
It might be a regional term, but every roofer handyman and dogwalker around here knows what it means.
We also have vent jacks.
The roofers in these parts are installing a split lead boot stack flashing and caulking around the top of it.
I tell my folks that its wrong and should to be replaced.
Roofers response "thats the way I've been doing it for years".
I call them roof jacks.
I like that 2 part split Oatey approach. It'd work.
Those things Mike linked to look like the breast ornaments @ a Madonna concert. [:-eyebrow
  • 7 months later...
Relacing an electric service mast flashings is an easy job. Just cut off the old flashing and install a Retro-Spin Flashing.
Slide it on and spin it closed, then nail tight. Easy job!
Then use a Retro-Split EPDM storm collar that matches the size of the galvanized mast pipe as a counter flashing.
Take a look at this web address: www.spinflashing.com
Now those are cool.[:-thumbu]
Tom
