CheckItOut Posted December 15, 2007 Report Posted December 15, 2007 This house had one step at the front door. The step was a solid poured concrete block adjoining the house. Height fine on this. However, stepping up into the threshold at the door from the block step was about 10.5". Best I can figure the code book, it discusses specifics with stairs but this is just one step. Same rules apply right or is there a loop hole?
kurt Posted December 15, 2007 Report Posted December 15, 2007 One step = 2 risers, no? Is there a landing?
CheckItOut Posted December 15, 2007 Author Report Posted December 15, 2007 Originally posted by kurt One step = 2 risers, no? Is there a landing? No landing. Picture a walkway leading up to a front door. There is one poured block, then you step into the foyer. If you removed the block, you'd have a 18" drop from the font door to the walkway.
kurt Posted December 15, 2007 Report Posted December 15, 2007 Well, you should have a landing, and the 10 1/2" riser is too high.
Jim Katen Posted December 15, 2007 Report Posted December 15, 2007 Originally posted by CheckItOut This house had one step at the front door. The step was a solid poured concrete block adjoining the house. Height fine on this. However, stepping up into the threshold at the door from the block step was about 10.5". Best I can figure the code book, it discusses specifics with stairs but this is just one step. Same rules apply right or is there a loop hole? There's no loop hole. This is a no brainer. There should be three steps. - Jim Katen, Oregon
