hausdok Posted December 1, 2007 Report Posted December 1, 2007 Introduction What is a radiant barrier? Radiant barriers are materials that are installed in buildings to reduce summer heat gain and winter heat loss, and hence to reduce building heating and cooling energy usage. The potential benefit of attic radiant barriers is primarily in reducing air-conditioning cooling loads in warm or hot climates. Radiant barriers usually consist of a thin sheet or coating of a highly reflective material, usually aluminum, applied to one or both sides of a number of substrate materials. These substrates include kraft paper, plastic films, cardboard, plywood sheathing, and air infiltration barrier material. Some products are fiber reinforced to increase the durability and ease of handling. Radiant barriers can be used in residential, commercial, and industrial buildings. However, this fact sheet was developed only for applications of radiant barriers in ventilated attics of residential buildings. For information on other applications, see the references at the end of the Fact Sheet. How are radiant barriers installed in a residential attic? Radiant barriers may be installed in attics in several configurations. The simplest is to lay the radiant barrier directly on top of existing attic insulation, with the reflective side up. This is often called the attic floor application. Another way to install a radiant barrier is to attach it near the roof. The roof application has several variations. One variation is to attach the radiant barrier to the bottom surfaces of the attic truss chords or rafter framing. Another is to drape the radiant barrier over the tops of the rafters before the roof deck is applied. Still another variation is to attach the radiant barrier directly to the underside of the roof deck. How do radiant barriers work? Radiant barriers work by reducing heat transfer by thermal radiation across the air space between the roof deck and the attic floor, where conventional insulation is usually placed. All materials give off, or emit, energy by thermal radiation as a result of their temperature. The amount of energy emitted depends on the surface temperature and a property called the "emissivity" (also called the "emittance"). The emissivity is a number between zero (0) and one (1). The higher the emissivity, the greater the emitted radiation. A closely related material property is the "reflectivity" (also called the "reflectance"). This is a measure of how much radiant heat is reflected by a material. The reflectivity is also a number between 0 and 1 (sometimes, it is given as a percentage, and then it is between 0 and 100%). For a material that is opaque (that is, it does not allow radiation to pass directly through it), when the emissivity and reflectivity are added together, the sum is one (1). Hence, a material with a high reflectivity has a low emissivity, and vice versa. Radiant barrier materials must have high reflectivity (usually 0.9, or 90%, or more) and low emissivity (usually 0.1 or less), and must face an open air space to perform properly. On a sunny summer day, solar energy is absorbed by the roof, heating the roof sheathing and causing the underside of the sheathing and the roof framing to radiate heat downward toward the attic floor. When a radiant barrier is placed on the attic floor, much of the heat radiated from the hot roof is reflected back toward the roof. This makes the top surface of the insulation cooler than it would have been without a radiant barrier and thus reduces the amount of heat that moves through the insulation into the rooms below the ceiling. Under the same conditions, a roof mounted radiant barrier works by reducing the amount of radiation incident on the insulation. Since the amount of radiation striking the top of the insulation is less than it would have been without a radiant barrier, the insulation surface temperature is lower and the heat flow through the insulation is reduced. Radiant barriers can also reduce indoor heat losses through the ceiling in the winter. Radiant barriers reduce the amount of energy radiated from the top surface of the insulation, but can also reduce beneficial heat gains due to solar heating of the roof. The net benefits of radiant barriers for reducing winter heat losses are still being studied. How does a radiant barrier differ from conventional attic insulation? Radiant barriers perform a function that is similar to that of conventional insulation, in that they reduce the amount of heat that is transferred from the attic into the house. They differ in the way they reduce the heat flow. A radiant barrier reduces the amount of heat radiated across an air space that is adjacent to the radiant barrier. The primary function of conventional insulation is to trap still air within the insulation, and hence reduce heat transfer by air movement (convection). The insulation fibers or particles also partially block radiation heat transfer through the space occupied by the insulation. Conventional insulations are usually rated by their R-value. Since the performance of radiant barriers depends on many variables, simple R-value ratings have not been developed for them. What are the characteristics of a radiant barrier? All radiant barriers have at least one reflective (or low emissivity) surface, usually a sheet or coating of aluminum. Some radiant barriers have a reflective surface on both sides. Both types work about equally well, but if a one-sided radiant barrier is used, the reflective surface must face the open air space. For example, if a one-sided radiant barrier is laid on top of the insulation with the reflective side facing down and touching the insulation, the radiant barrier will lose most of its effectiveness in reducing heating and cooling loads. Emissivity is the property that determines how well a radiant barrier will perform. This property is a number between 0 and 1, with lower numbers indicating better potential for performance. The emissivity of typical, clean, unperforated radiant barriers is about 0.03 to 0.05. Hence they will have a reflectivity of 95 to 97 percent. Some materials may have higher emissivities. It is not always possible to judge the emissivity just by visual appearance. Measured emissivity values should be part of the information provided by the manufacturer. A radiant barrier used in the attic floor application must allow water vapor to pass through it. This is necessary because, during the winter, if there is no effective vapor retarder at the ceiling, water vapor from the living space may condense and even freeze on the underside of a radiant barrier lying on the attic floor. In extremely cold climates or during prolonged periods of cold weather, a layer of condensed water could build up. In more moderate climates, the condensed water could evaporate and pass through the radiant barrier into the attic space. While most uniform aluminum coatings do not allow water vapor to pass through them, many radiant barrier materials do allow passage of water vapor. Some allow water vapor passage through holes or perforations, while others have substrates that naturally allow water vapor passage without requiring holes. However, excessively large holes will increase the emissivity and cause a reduction in the radiant barrier performance. The ability to allow water vapor to pass through radiant barrier materials is not needed for the roof applications. What should a radiant barrier installation cost? Costs for an attic radiant barrier will depend on several factors, including the following: Whether the radiant barrier is installed by the homeowner or by a contractor. Whether the radiant barrier will be installed in a new home (low cost) or in an existing home (possibly higher cost if done by a contractor). What extra "features" are desired; e.g., a radiant barrier with perforations and reinforcements may be more expensive than a "basic" radiant barrier. Any necessary retrofit measures such as adding venting (soffit, ridge, etc.) Whether the radiant barrier is installed on the attic floor or on the rafters. Radiant barrier costs vary widely. As with most purchases, some comparison shopping can save you money. A survey of nine radiant barrier manufacturers and contractors representing 14 products, taken by the Reflective Insulation Manufacturers Association (RIMA) in 1989, shows the installed costs of radiant barriers to range as shown in Table 1. In some cases, radiant barriers are included in a package of energy saving features sold to homeowners. When considering a "package deal", you may want to ask for an itemized list that includes material and installation costs for all measures included. Then shop around to see what each item would cost if purchased individually before you make a decision. What should conventional insulation cost? Heating and cooling bills can also be reduced by adding conventional attic insulation. So that you can have some basis for comparison shopping, typical installed costs for adding various levels of insulation are given in Table 2. These costs are typical for insulation installed by contractors. Actual insulation costs will vary from region to region of the country, will vary with the type of insulation selected (blown, or loose-fill, insulation is usually lower in price than "batt" insulation), and may vary from one local contractor to another. You can expect to deduct 20% to 50% for a do-it-yourself application. You should always check with your local or state energy office or building code department for current insulation recommendations or see the DOE INSULATION FACT SHEET. Next Section - Effect of Radiant Barriers on Heating and Cooling Bills Source: U.S. Dept. of Energy & Oak Ridge National Laboratory Building Envelope Research Program Key to Abbreviations. Information Services About This Fact Sheet
hausdok Posted December 4, 2007 Author Report Posted December 4, 2007 Hi All, For those of you who are interested, I've finished uploading the entire 5 part Radiant Barrier Document. You can continue reading it from the hot link at the bottom of the article above. ONE TEAM - ONE FIGHT!!! Mike
hausdok Posted December 5, 2007 Author Report Posted December 5, 2007 Hi All, My apologies to everyone. I didn't realize that folks couldn't get to parts 2,3,4, and 5 of this article because I'd parked it in an area of the forum that only moderators and admin folks can access. I've fixed it now and I logged out and logged back in under a different name to check it to ensure it's 100% accessible. To read it, folks will still need to be TIJ members which is no big deal, because membership is FREE, so don't let that stop you. Many thanks to Cyndy Patzman of Bellingham, WA for bringing this to my attention and then being patient with me while I took forever to figure out that it wasn't she who was putting in the wrong password - it was I who'd parked it incorrectly. What can I say, I think I'm betting that oldtimers disease. ONE TEAM - ONE FIGHT!!! Mike
cyndyt99 Posted February 1, 2008 Report Posted February 1, 2008 Is it beneficial to have both blown insulation and radiant barrier?
hausdok Posted February 1, 2008 Author Report Posted February 1, 2008 Hi, I suppose it could be if you could keep the barrier clean. Their effectiveness is drastically decreased when they get dirty. However, blown-in insulation and dust go hand-in-hand, so I don't think it's practical. OT - OF!!! M.
davidlord Posted February 1, 2008 Report Posted February 1, 2008 I have Plytanium Thermostat (GP product) on my house and blown insulation and the difference in attic temps compared to a house with conventional plywood or OSB are dramatic.
thekings8 Posted May 24, 2008 Report Posted May 24, 2008 Hey Mike, I have a question? I am relatively new to radiant barrier so here it goes. I live in Las Vegas, NV and recently upgraded my attic insulation from an R-4 to an R-51 (my house is approx 32 years old) so would it be beneficial to install radiant barrier on the roof sheeting under the shingles and tar paper ? It would seem that if it goes on the roof then the heat would be prevented (to some degree from getting into the attic to begin with thereby making my insulation just that more effective. any input is appreciated
hausdok Posted May 24, 2008 Author Report Posted May 24, 2008 Hi, My understanding is that a radiant barrier doesn't work unless there is an air space in front of it. In other words, if it is sandwiched between the rafters and the roof deck, it will reflect heat from the house downward but won't work to reflect heat from the exterior back outward and will simply conduct exterior heat - either radiant or convection that heats up the roof - into the attic space and give it off again as convection. My understanding of what they are doing in Florida is they are installing the barrier material on the underside of rafters with the depth of the rafter above the barrier. This way, it can reflect in both directions. In addition to that, there are new metal roofs which use special coatings to lessen the amount of heat they will transfer to the interior of a home. There was also some research done by an entity called the Florida Solar Energy Research center, or something like that, wherein they'd tested new paints that are formulated with microscopic ceramic beads. Apparently, this paint, when applied to the underside of a roof deck or to the surface of a roof slows the migration of heat through a surface, thus slowing solar gain during the day and loss of interior heat during the night when exterior temperatures drop below interior temps. It's funny how much you can control solar heat gain by manipulating surfaces. Back in early October, I went down to Florida to repair the leaking roof on my mother's manufactured home. It was a painted metal roof and the joints were sealed with some foil-faced peel-'n-seal. The roof was dingy gray, although it had originally been white, and during the day she was running the A/C full time to keep the interior of that home tolerable. Initially, I cleaned the entire roof with a pretty strong chemical to strip off the old dingy white paint all the way down to the sheetmetal. Where the sun hit that bare metal, the surface got so hot that it actually started to melt the soles of my shoes. After I'd applied 10-inch wide vinyl faced peel-'n-seal to all of the seams and had rolled them in place, I coated the roof with a fresh coat of a white elastomeric acrylic. As soon as that stuff cured, and I walked on it, the surface was barely warmer than body temperature during the day. I applied a second coat to make it even whiter, and the surface was even cooler after it dried than it was with the first layer. I called her last week to see how she was doing and asked if she'd had any problems with the roof. She told me that it's fine and that her energy bills are markedly lower and the house overall is much cooler inside during the day; just by simply making the roof reflect more heat than it absorbs. I told her to make sure that she has someone go up there a couple of times a year, clean the roof with a mild detergent, and touch it up where necessary. ONE TEAM - ONE FIGHT!!! Mike
