I bought a Modine Hot Dawg Garage heater. The only venting solution I have is to attach the vent from the heater to the main B-Vent for my furnace and water heater. I already did the calculation for the current B-vent to see if it can handle the additional BTU'S and it can. Running up through the house is 5in B-vent. The run from the heater to the main B-vent stack is around 5ft. My question is: Can i attach single wall vent pipe into the B-vent? If so How do I go about doing that?
Thanks, Mike
Hi Mike,
Not to be unkind, but this is a home inspectors site, not a do-it-yourselfer's advice site. I think we were more than patient when you visited last time to ask your questions about the house-sized furnace you wanted to put in your garage, but we advised you then to see the services of a professional and explained, in many ways, how dangerous it is to do this work yourself.
Please, spend a couple of hundred bucks for a professional to come out and help you install that thing.
[:-angel] I just finished a NCI (National Comfort Institute) certification class on CO (carbon monoxide) and combustion and I would highly recommend against teeing 3 vents together, especially if one is forced draft . If you do not have the tools to check for proper draft don't do it. The chances of back drafting are very great with the production of CO likely.
be safe
jimj
