One of the items I check is the maximum circuit breaker size for a unit and check to make sure that the proper size breaker is in the panel.
Today I came across a matched set of compressors. The 2 ton unit called for a 40amp HACR and the three ton called for a 15 amp HACR.
This seemed quite odd to me, I usually see larger units with larger breakers.
As I said, they are identical units, except size.
How old were the things? It may have something to do with the 13 SEER change. I regularly see newer two-ton units that look big enough to cool a Wal-Mart. The old rule of thumb was that you'd have 10 amps of over-current protection for every ton of capacity.
The units are brand new. I'm wondering if it's a typo on the label. I find it odd that the smaller unit calls fo a 40, etc., but I'm even more taken back that calls for more than the larger unit.
