DanAuito Posted March 31, 2004 Report Share Posted March 31, 2004 Thanks guys here's a list,if you have anything that you can further add, it would be appreciated. Dan Inadequate drainage downspouts that empty next to the foundation windows caulked in, instead of with proper splines and a head flashing stoops poured directly against the house w/o capillary breaks insufficient siding to grade clearance blocked vents poor attic ventilation sloppy HVAC poor flashings of every sort roofs without drip edging fans venting into attics and crawls dryer ducting too long furnaces improperly vented water heaters without proper T & P or seismic bracing siding installed incorrectly no weeps in brick veneer faux stone without weeps meeting grade improperly installed shingles Poor grade drainage Exposed / uncaulked nails on the roof Errors in neutral bar wiring (Main panels) Errors in neutral bar wiring (Subpanels) Lack of GFCI's in required locations Sinks / tubs that don't hold water (stopper leaks or is missing) Errors with water heater relief valves and piping Non-professional work where a professional was needed Flange bolts and other fasteners not tightened at column(s)/beam Anchor bots not tightened at sill/sill plate(s) Improper joist boring/notching/end-bearing No drain pan under water heater T & P valve drain has a reduction in size No back flow (anti siphon) prevention in commodes or at exterior hose bibs Insuffiecient air gap at refill tube in commodes A/C condenser under or over fused Trees and/or heavy foliage too close to house Dead bolts on exterior doors requiring a key from the inside No vapor barrier in crawl space. Homemade shims for support columns. Bath vent exhausting to attic. Plastic dryer duct. Real bad! Metal dryer duct with screws. (collects lint) Gutters rusting at seams. Debris in roof valleys. Hot water heater set too high. Sellers trying to hide previous leaks under sinks. - Almost always, insufficient attic insulation in older homes. - Wood to ground contact (posts). - Realtors in a hurry. Breaks in the firewall between the garage and living space of the house. Either an attic access door made from inadequate material, or missing. Door into living space from garage has none or inadequate weather stripping Doors opening out over stairs, and stairs without handrails. Inconsistent rise in bottom and/or top step. Uninsulated attic pull-down stairs. Dan[b)] Link to comment Share on other sites More sharing options...
