Phillip Posted November 12, 2007 Report Share Posted November 12, 2007 Here is a gas package unit that has been open up and the coil have been removed. I thought that some of the newer inspectors might like a look at some of the interior parts. Image Insert: 133.55 KB Image Insert: 134.31 KB Image Insert: 111.59 KB Link to comment Share on other sites More sharing options...
John Dirks Jr Posted November 13, 2007 Report Share Posted November 13, 2007 Does this outdoor unit connect to ductwork that goes into the house? I think I have seen something similar except it was oil fired. Link to comment Share on other sites More sharing options...
Phillip Posted November 13, 2007 Author Report Share Posted November 13, 2007 John, Yes this unit connects to the ductwork for the house. It is a package unit with heating and cooling as one unit which is set on the exterior of the house. This one use gas to heat with. There are packaged heat pump systems. I have never seen one that used oil, but in my area no one uses oil to heat with. So in areas there could be ones that uses oil. How about it from the guys or gals that work in areas that use oil to heat with, Is there a oil fired package unit out there? Link to comment Share on other sites More sharing options...
Inspectorjoe Posted November 13, 2007 Report Share Posted November 13, 2007 Originally posted by Phillip How about it from the guys or gals that work in areas that use oil to heat with, Is there a oil fired package unit out there? I'm in fuel oil country and I've never seen one, but even gas residential package units just aren't used around here. The only time I'll see a gas package unit, would be a rooftop mounted one on a commercial building. A Google search shows that Thermo-Pride makes them. In very cold locales, I imagine that they'd be pretty prone to the fuel oil gelling, especially in the tiny line from the pump to the nozzle. Maybe that's why I've never seen one. Thermo-Pride package unit Link to comment Share on other sites More sharing options...
Brian G Posted November 13, 2007 Report Share Posted November 13, 2007 At least that one has the burners up the side. A lot of the older ones I see here have them across the very bottom of the unit, where they're more prone to rust and damn hard to inspect. Brian G. Love That Highly Visible Heat Exchanger [:-magnify Link to comment Share on other sites More sharing options...
