John Dirks Jr Posted November 8, 2007 Report Posted November 8, 2007 Consider the supply pressure is way too high and the house is on city water. Does the responsibility to control the pressure fall on the home owner or the jurisdiction providing the service?
Les Posted November 8, 2007 Report Posted November 8, 2007 That is a real tricky question. Most water providers are commissions or boards, sometimes authorities. They will usually have very limited responsibility. That said, they are selling a product and that product must meet a serviceability or use criteria. Reasonable expectation. They must either claim exemption as a public service or waiver it in the terms of service agreement. Either way, the user is likely the responsible party. Of course the real question is how much pressure is the house designed to safely use. Anyone know?
ozofprev Posted November 8, 2007 Report Posted November 8, 2007 Too much pressure? They are fortunate. Just have a pressure reducer installed and smile.
Les Posted November 8, 2007 Report Posted November 8, 2007 Ya, we installed Jenny in our front office as a pressure reducer! She does little or no volume, just reduces the pretchure!
Scottpat Posted November 8, 2007 Report Posted November 8, 2007 Originally posted by AHI Consider the supply pressure is way too high and the house is on city water. Does the responsibility to control the pressure fall on the home owner or the jurisdiction providing the service? In every instance that I have seen it is the homeowners or builders responsibility.
Jim Katen Posted November 8, 2007 Report Posted November 8, 2007 Originally posted by AHI Consider the supply pressure is way too high and the house is on city water. Does the responsibility to control the pressure fall on the home owner or the jurisdiction providing the service? Homeowner. - Jim Katen, Oregon
John Dirks Jr Posted November 8, 2007 Author Report Posted November 8, 2007 I recently measured a pressure of 110psi at a laundry basin. I felt pretty comfortable in calling that out as excessive. I recommended that a plumber be contacted to explore methods of reducing the pressure to a level of not more than 80psi.
Tim Maxwell Posted November 8, 2007 Report Posted November 8, 2007 In the metro area I see a PRV in almost all houses that are 25 - 30 years old or less. The ones over 30 years old don't have them but usually need them. Without the PRV 100 - 120 psi is common for my area of the country. I say something like: The water pressure is beyond the normal range of 40 - 80# psi. High pressure will put stress on joints, valves, and faucets which can lead to leaks. I recommend review by a licensed plumber before closing for installation or adjustment of the pressure regulator valve.
paul burrell Posted November 9, 2007 Report Posted November 9, 2007 By far most homes I inspect that have polybutlyene branch lines have very low water pressure. I never could figure out why. [] Paul B.
hausdok Posted November 10, 2007 Report Posted November 10, 2007 Hi Paul, Are you sure it's pressure that's low and not low volume. They have a far smaller inside diameter than 1/2 inch copper or galvanized pipe, so flow is going to be restricted. OT - OF!!! M.
paul burrell Posted November 10, 2007 Report Posted November 10, 2007 Originally posted by hausdok Hi Paul, Are you sure it's pressure that's low and not low volume. They have a far smaller inside diameter than 1/2 inch copper or galvanized pipe, so flow is going to be restricted. OT - OF!!! M. Could be Mike I never considered about that. Maybe some sharp plumbers out there can elaborate on pressure restriction of PB versus COPPER, CPVC and PEX. I heard on news today that PB is still causing home owners problems and their class action warranties have expired. My daughter just bought a home with expired warranty on PB. I told Her it could cost her probably $5,000 to replace it and she negotiated a price reduction for that amount plus a few other concessions. Naturally I inspected the home for free so I think She came out OK. Paul B.
msteger Posted November 10, 2007 Report Posted November 10, 2007 I'd also agree that the home owner is responsible. Install a pressure reducer and be done with it.
