randynavarro Posted October 31, 2007 Report Posted October 31, 2007 I see this commonly. One would have to slide the range out to shut the gas off. IRC states the valves "shall be provided with access". I'm too lazy to look up in my National Fuel Gas Code right now. Anyone making a significant issue of this?
hausdok Posted October 31, 2007 Report Posted October 31, 2007 Hi Randy, They're actually not usually that hard to reach. You pull out the pot drawer, lift it off it's track, lie down on the floor, and you can reach it. OT - OF!!! M.
randynavarro Posted October 31, 2007 Author Report Posted October 31, 2007 I'm referring to situations where the valve is buried behind the sheet metal case or something else. In essence, they're not accessibe unless the range is completely removed.
Brandon Chew Posted October 31, 2007 Report Posted October 31, 2007 The valve at the appliance is there so that the gas to the appliance can be shut off when the appliance is being serviced and replaced, without turning off the gas to the entire house. In an emergency situation, you would use the service shutoff near the gas meter. Can a service technician gain access to the appliance shutoff without too much difficulty? A reasonable person would probably say that sliding the range out from the wall is not too difficult for a qualified service technician.
chicago Posted October 31, 2007 Report Posted October 31, 2007 It is the same with many washer dryer combos. Not worth writing up. The only emergency where you need to shut it down quick, would more than likely be a hose leak in which case you would need to move the stove anyway. (let me add to blow out pilots on older stoves first.)I learned the hard way.
Chad Fabry Posted October 31, 2007 Report Posted October 31, 2007 They're actually not usually that hard to reach. You pull out the pot drawer, lift it off it's track, lie down on the floor, and you can reach it. Mike you may want to be more clear: Pull out the pan drawer under the stove. Telling some of my clients to pull out the pot drawer is likely to have an adverse impact on their attention span.
MMustola Posted November 1, 2007 Report Posted November 1, 2007 I have never seen a valve installed any other way than behind the unit and have never called it out as a problem. It would be nice if the had a keyed valve in the floor in front of the appliance like a gas fireplace
randynavarro Posted November 1, 2007 Author Report Posted November 1, 2007 Yes. Re-reading my original post, I was a bit unclear. I too, have never seen a shutoff valve installed anywhere other than behind the range. But I've always questioned whether it was "accessible" or not as defined by Fuel Gas Code, IRC, and others. I think Brandon's answer provided the best clarity; if there's an emergency, shut off at the meter. Otherwise, a reasonably experienced tech. can slide the range out and shut off from there.
