Do you know if there is a requirement for newer houses to have a separate water supply cut off valve, or line for that matter, for the dishwasher? Older houses just have the supply hooked up at the sink supply line but some new homes have a separate valve. If a requirement, do you know when this was?
Each plumbing fixture is supposed to have a shut-off valve. It's not a new requirement.
It is not uncommon to see them on a double shutoff with compression fittings .But Ditto with the above.
I guess losing hot water to the sink would be a good reminder to fix the dishwasher though.
