Ken Meyer Posted October 18, 2007 Report Posted October 18, 2007 I've seen several older homes that have had new electrical service added, and the main breaker is located outdoors in an enclosure next to the meter. Is this required either by the municipality (Portland, OR) or the power company? Is it to allow emergency personnel to be able to disconnect power to the house or.....? Can the homeowner padlock the enclosure with the main breaker in it? Anyone walking by could shut off power to the house. Thanks
tbird Posted October 18, 2007 Report Posted October 18, 2007 In AZ - Most all of our electrcal panels and main breakers are located outside. Some people do lock them. but most do not. That is the first thing firefighters shutoff in an event of a fire so they do not have to run into a live wire situation.
Jim Katen Posted October 18, 2007 Report Posted October 18, 2007 Originally posted by Ken Meyer I've seen several older homes that have had new electrical service added, and the main breaker is located outdoors in an enclosure next to the meter. Is this required either by the municipality (Portland, OR) or the power company? Is it to allow emergency personnel to be able to disconnect power to the house or.....? It's really quite common. The reason is that you want to have the disconnect as close to the meter as possible so that you don't have unprotected conductors leading halfway across the house to the distribution panel. It was common for older houses to have the meter at one location and the service panel far distant from it. The NEC no longer allows this. Be aware that there's a local exception to this rule that allows retrofit applications to have the new service panel distant from the meter. However, many electricians either aren't aware of this exception or they're just doing a good job by not taking advantage of it. Can the homeowner padlock the enclosure with the main breaker in it? Anyone walking by could shut off power to the house. Thanks Yes, the homeowner can padlock it. There's really no good reason to though. The only time bad people shut power to the house is in the movies. - Jim Katen, Oregon
msteger Posted October 18, 2007 Report Posted October 18, 2007 It puzzles me that you guys out west have your electrical panels and/or main disconnects outside. I've heard of this before and every where I saw it mentioned said most areas forbid home owners from locking their main disconnect in case the fire dept. or other needs to get to it. A few mobile home parks around here, however, do have the main disconnect panel in the side yard, and these are almost always rusted out. Heck, growing up, if I were out west, I would have had fun going around shutting off everyone's power and messing with them.
Jim Katen Posted October 18, 2007 Report Posted October 18, 2007 Originally posted by msteger It puzzles me that you guys out west have your electrical panels and/or main disconnects outside. I've heard of this before and every where I saw it mentioned said most areas forbid home owners from locking their main disconnect in case the fire dept. or other needs to get to it. I've never heard of such a rule. If the fire department want's to shut the power, they just pull the meter. They don't need no pansy switch. A few mobile home parks around here, however, do have the main disconnect panel in the side yard, and these are almost always rusted out. Yes. Most manufactured homes aren't real property. So the lot needs it's own service, independent from the home. The only ones' I see rused out are quite old -- from the '70s. Then again, maybe our weather is kinder to these things. Heck, growing up, if I were out west, I would have had fun going around shutting off everyone's power and messing with them. It's a bit odd that no one does that. It may be that here, out west, homeowners are more likely to pull out the old 30-06 and fire a few rounds into the dark if they suspect a prowler. - Jim Katen, Oregon
Ken Meyer Posted October 18, 2007 Author Report Posted October 18, 2007 I knew Jim would have the reason. My thought was that a burglar could shut off the alarm system easily with the outside breaker being so accessible, but I guess they haven't figured that one out. Matthew makes a good point, what a great Halloween prank! I grew up in a small town (a village, really), and we used to climb up the one utility pole where the photocell that controlled the street lights was, and shine a flashlight down on it until it activated and shut off all the streetlights in town. For a few brief minutes, we felt pretty powerful!
hausdok Posted October 18, 2007 Report Posted October 18, 2007 Hi, You don't need to padlock it, just use a heavy zip-tie. That way it will keep all but the most determined away from it and won't hinder anyone in a real emergency. ONE TEAM - ONE FIGHT!!! Mike
Tim Maxwell Posted October 18, 2007 Report Posted October 18, 2007 I've lived the last 15 years in two different houses with the disconnect outside. Not one prankster in all those years. Not even on Halloween. I do see the pad locks on them several times a year on inspections though. Horror movie fans........
hausdok Posted October 18, 2007 Report Posted October 18, 2007 Hi, Sure, it's not like the plastic weatherproof covers on most exterior meter arrays can withstand a lot of force anyway. If it's padlocked and someone wants to get into it, all it takes is a chick cut with a Buck knife or a sharp whack with a hammer to break the plastic hinges. The covers are easily replaced. OT - OF!!! M.
Jim Baird Posted October 19, 2007 Report Posted October 19, 2007 I won't quote the section, but I think it's NEC for remote (don't even ask for definition of that) distribution panel. The idea is to put the feeder under overcurrent protection and to locate disconnect as close as possible to service entrance location.
Tim H Posted October 19, 2007 Report Posted October 19, 2007 Originally posted by msteger It puzzles me that you guys out west have your electrical panels and/or main disconnects outside. I've heard of this before and every where I saw it mentioned said most areas forbid home owners from locking their main disconnect in case the fire dept. or other needs to get to it. A few mobile home parks around here, however, do have the main disconnect panel in the side yard, and these are almost always rusted out. Heck, growing up, if I were out west, I would have had fun going around shutting off everyone's power and messing with them. Its not just out west. At least 95% of the homes that I inspect that are 20 years old or younger have outside disconnects. This mornings inspection was the first (panel) I have encounteed that was padlocked.
chicago Posted October 19, 2007 Report Posted October 19, 2007 Heck ,if anyone wants to shut you off they could just pull the meter head. It is getting more common around here especially on 200 amp service.
Brandon Chew Posted October 19, 2007 Report Posted October 19, 2007 Most of the service disconnects I see around here are inside. It might have something to do with the homeowner, while in his underwear, needing to wade through waist-deep snow in order to get around the house to an outside disconnect near the meter, vs running down some steps to his basement. In an emergency the FD is going to yank the meter.
zekideguito Posted November 14, 2007 Report Posted November 14, 2007 it is better to put or install your main circuit breaker inside the house, how ever if your meter installed in pedestal or 25 meter from your main circuit breaker therefore it is necessary to install also a main circuit breaker for the sole reason of protection. http://electricalengineeringtour.blogspot.com Thanks
tbird Posted November 14, 2007 Report Posted November 14, 2007 Originally posted by Brandon Chew Most of the service disconnects I see around here are inside. It might have something to do with the homeowner, while in his underwear, needing to wade through waist-deep snow in order to get around the house to an outside disconnect near the meter, vs running down some steps to his basement. In an emergency the FD is going to yank the meter. "Basements", what are those? Very few homes here have basements. Just scratch the surface, poor your footers, slab and away you go! I can remember, in the last four years of inspections, of finding just a couple older houses without having the disconnects outside. In fact, all older homes with new upgraded panels have the disconnects outside. It's just the way it is done here.
