NJinspector Posted October 6, 2007 Report Share Posted October 6, 2007 Had my first inspection in a while yesterday. Please tell me all Septembers are not that slow. Anyway, this was a 1930ish house. The age of this house indicates that this is galvanized but, how do I know for sure? Image Insert: 232.08 KB Is it alright to have the service drop laying on top of these other wires? Image Insert: 256.32 KB thanks Link to comment Share on other sites More sharing options...
Mark P Posted October 6, 2007 Report Share Posted October 6, 2007 I call it galvanized. The dull silver finish is the zinc coating. I've read about un-coated steel pipes used back in the 1800's, but galvanized was very common by the 1930. Lead pipes looking nothing like your picture, they have a very unique union that looks a bit like a tulip bulb, and of course it is neither plastic nor copper. Regarding the electrical line. I would note it and recommend they contact the utility company. In some areas the home owner is responsible for the line that runs from the pole to the house and the utility company is responsible for the line that runs between poles. But I would bet that the utility company would not want that line resting on the other one and would come out and correct. Link to comment Share on other sites More sharing options...
Chad Fabry Posted October 6, 2007 Report Share Posted October 6, 2007 It's galvanized but the dull silver in the photo is paint. It's likely to be occluded like a fat man's arteries and very likely to be at the end of its life. How were the pressure/ volume drops when you ran multiple fixtures? Link to comment Share on other sites More sharing options...
NJinspector Posted October 6, 2007 Author Report Share Posted October 6, 2007 Hey Chad, thanks for the response. I figured the same thing, but when I ran multiple fixtures, the water volume was still good, even at the second floor bathroom. I dont measure water pressure. I wonder what percentage of inspectors are testing pressure, and those inspectors are testing every home they inspect? or just when they see a problem that may indicate low pressure? Link to comment Share on other sites More sharing options...
Scottpat Posted October 6, 2007 Report Share Posted October 6, 2007 Originally posted by NJinspector Hey Chad, thanks for the response. I figured the same thing, but when I ran multiple fixtures, the water volume was still good, even at the second floor bathroom. I don't measure water pressure. I wonder what percentage of inspectors are testing pressure, and those inspectors are testing every home they inspect? or just when they see a problem that may indicate low pressure? I test the pressure on about 50% of my inspections, it all depends on what I find when I turn it on. I'm not testing for low pressure, but rather for "High" pressure over 80 psi. Link to comment Share on other sites More sharing options...
Neal Lewis Posted October 6, 2007 Report Share Posted October 6, 2007 Jason, most any threaded pipe is galvanized. I've never seen threaded brass used as service, but I guess it's possible. BTW, NJ standards don't require us to identify the service material. I have a pressure gauge but don't use it. It's the flow that matters. Link to comment Share on other sites More sharing options...
inspector57 Posted October 6, 2007 Report Share Posted October 6, 2007 I test for pressure on every house, a lot of my inspections are in newer suburbs that were built and then they got a new water tower with high pressure. Anything over 80 lbs needs a regulator, and I have NEVER seen an expansion tank even when they put in a regulator. Some times the regulator is hidden and I might sneek next door and check their pressure just out of curiosity. Link to comment Share on other sites More sharing options...
John Dirks Jr Posted October 7, 2007 Report Share Posted October 7, 2007 With that service drop hanging loose like that, how close did it come to the ground at its lowest point? Minimums should be; 18' over street 12' over driveway 10' over any pedestrian accessible area 8' over flat roofs Link to comment Share on other sites More sharing options...
ghentjr Posted October 7, 2007 Report Share Posted October 7, 2007 Originally posted by NJinspector Had my first inspection in a while yesterday. Please tell me all Septembers are not that slow. Anyway, this was a 1930ish house. The age of this house indicates that this is galvanized but, how do I know for sure? USE A MAGNET. A MAGNET WILL NOT STICK TO BRASS, COPPER OR LEAD. Is it alright to have the service drop laying on top of these other wires? thanks NO! BUT HOW WAS THE CONNECTION AT THE HOUSE? WHAT CAUSED THE LINE TO SAG SO MUCH? Link to comment Share on other sites More sharing options...
