Steven Hockstein Posted September 28, 2007 Report Share Posted September 28, 2007 We are designing a pool house for a client and the exterior glass walls of the rooms facing the pool will slide open to create a continuous space between the exterior and interior. The walls are located under large covered porches. Do the electric outlets in these rooms have to be GFCI protected? These rooms are more than 20 feet from the pool so this is not an issue. Is this a judgement call or covered somewhere in the NEC? Thanks in advance for any help. Link to comment Share on other sites More sharing options...
John Dirks Jr Posted September 28, 2007 Report Share Posted September 28, 2007 Well, technically speaking, porches are considered exterior. So anything under them is also exterior, correct? Either way, when considering the expense of the project at hand, why not just add the GFI protection anyway? How much more could it cost? Link to comment Share on other sites More sharing options...
Jim Katen Posted September 28, 2007 Report Share Posted September 28, 2007 Originally posted by Steven Hockstein We are designing a pool house for a client and the exterior glass walls of the rooms facing the pool will slide open to create a continuous space between the exterior and interior. The walls are located under large covered porches. Do the electric outlets in these rooms have to be GFCI protected? These rooms are more than 20 feet from the pool so this is not an issue. Is this a judgement call or covered somewhere in the NEC? Thanks in advance for any help. I can't find anything in the NEC that would require them in that location. 210.8 certainly doesn't require it. If the structure is more than 20 feet from the pool, I suspect that the requirements in 680 don't apply at all. My understanding of pools is weak though. Ask Cramer or Hansen to be sure. On the other hand, if you're the architect on this one, why not just go ahead and spec them? The cost is minimal and the present generation of GFCIs rarely nuisance trip. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Steven Hockstein Posted September 28, 2007 Author Report Share Posted September 28, 2007 You are right, the cost is not a problem (there is no budget restriction). My instinct says that they should be GFCI protected. I just was not sure of the exact requirement and what is considered "Exterior" space in the NEC. I was hoping that someone from areas where this situation is more common could tell me how the GFCI requirement is enforced. Link to comment Share on other sites More sharing options...
inspector57 Posted September 28, 2007 Report Share Posted September 28, 2007 Exterior outlets need to be GFCI protected. IRC E3802.3 Says ALL exterior outlets. I would think if it is EVER part of the exterior room, then it needs protection. There is no reason NOT to protect it, especially if it is near a pool area. This is cheap life insurance. Jim Link to comment Share on other sites More sharing options...
Jim Katen Posted September 28, 2007 Report Share Posted September 28, 2007 Originally posted by inspector57 Exterior outlets need to be GFCI protected. IRC E3802.3 Says ALL exterior outlets. I would think if it is EVER part of the exterior room, then it needs protection. There is no reason NOT to protect it, especially if it is near a pool area. This is cheap life insurance. Jim Well, except that Steven describes the outlets as being inside the rooms. 3802 doesn't say anything about requiring GFCIs in rooms that have exterior doors. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
inspector57 Posted September 28, 2007 Report Share Posted September 28, 2007 and the exterior glass walls of the rooms facing the pool will slide open to create a continuous space between the exterior and interior From the description, the interior and exterior line is erased when the WALL is removed and it would then be an exterior room. Link to comment Share on other sites More sharing options...
Jim Katen Posted September 29, 2007 Report Share Posted September 29, 2007 Originally posted by inspector57 and the exterior glass walls of the rooms facing the pool will slide open to create a continuous space between the exterior and interior From the description, the interior and exterior line is erased when the WALL is removed and it would then be an exterior room. Um, no. Opening a door doesn't make an interior space into an exterior space. My living room has large glass doors that I leave open throughout most of the summer. That doesn't make my living room an exterior space. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Chad Fabry Posted September 29, 2007 Report Share Posted September 29, 2007 That doesn't make my living room an exterior space Tell that to a red squirrel. Link to comment Share on other sites More sharing options...
Steven Hockstein Posted September 29, 2007 Author Report Share Posted September 29, 2007 Originally posted by Jim Katen Originally posted by inspector57 and the exterior glass walls of the rooms facing the pool will slide open to create a continuous space between the exterior and interior From the description, the interior and exterior line is erased when the WALL is removed and it would then be an exterior room. Um, no. Opening a door doesn't make an interior space into an exterior space. My living room has large glass doors that I leave open throughout most of the summer. That doesn't make my living room an exterior space. - Jim Katen, Oregon You both debate this issue very well. Now I feel even more justified in my question. Link to comment Share on other sites More sharing options...
Jim Katen Posted September 29, 2007 Report Share Posted September 29, 2007 Originally posted by Steven Hockstein . . . You both debate this issue very well. Now I feel even more justified in my question. I suspect that the building's details make a big difference. If the building has a concrete floor that's continuous with the surrounding area and if the sliding walls are likely to be slid open in spring and left that way till fall, then I'd agree with Jim L -- it's an exterior room. On the other hand, if the interior floor is wood or carpet and the walls are likely to be closed when the room isn't in use, then it's just a poolhouse with big doors. Either way, it's cheap easy and safe to just install the GFCI protection and not have to worry about it anymore. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
randynavarro Posted September 29, 2007 Report Share Posted September 29, 2007 I've seen this dilemma played out in deciding whether to install an interior or exterior rated service enclosure. What is outside? Link to comment Share on other sites More sharing options...
Richard Moore Posted September 29, 2007 Report Share Posted September 29, 2007 I'm not totally clear on the set-up and, therefore, the "requirements", and this may be over-simplifying it, but...I would ask myself; "Is anyone ever likely to come in contact with anything plugged into the various receptacles while still wet from the pool or even just wet feet from the yard?" I'm guessing the answer to that would be yes. Link to comment Share on other sites More sharing options...
Scottpat Posted September 29, 2007 Report Share Posted September 29, 2007 To be on the safe side I would install the GFCI's. Very good chance that something plugged into on of those outlets will end up outside. Link to comment Share on other sites More sharing options...
chicago Posted October 3, 2007 Report Share Posted October 3, 2007 The very fact it is being debated says to er on the side of safety. In three months it will be required anyway. Link to comment Share on other sites More sharing options...
msteger Posted October 6, 2007 Report Share Posted October 6, 2007 Originally posted by AHI Well, technically speaking, porches are considered exterior. So anything under them is also exterior, correct? Either way, when considering the expense of the project at hand, why not just add the GFI protection anyway? How much more could it cost? Ditto.. I would consider the porch to be exterior, so right there, it should be GFCI protected. Since these things only cost $7~$10, put 'em in. Link to comment Share on other sites More sharing options...
kasterko Posted October 6, 2007 Report Share Posted October 6, 2007 Originally posted by chicago The very fact it is being debated says to er on the side of safety. In three months it will be required anyway. In Three months meaning the 2008 NEC? Are GFCI requirements changing too? I've heard some thngs about AFCI's being required in more places. I guess we'll all need to be up on he new stuff fairly quickly. Link to comment Share on other sites More sharing options...
Chad Fabry Posted October 6, 2007 Report Share Posted October 6, 2007 Ditto.. I would consider the porch to be exterior, so right there, it should be GFCI protected. Since these things only cost $7~$10, put 'em in. Since they made them so they won't work if line/load are reversed they're about 20-25 bucks. Still cheap. Link to comment Share on other sites More sharing options...
