R311.5.3.2 Tread depth. The minimum tread depth
shall be 10 inches (254 mm). The tread depth shall be
measured horizontally between the vertical planes of the
foremost projection of adjacent treads and at a right angle
to the tread’s leading edge. The greatest tread depth
within any flight of stairs shall not exceed the smallest by
more than 3/8 inch (9.5 mm). Winder treads shall have a
minimum tread depth of 10 inches (254 mm) measured
as above at a point 12 inches (305) mm from the side
where the treads are narrower.Winder treads shall have a
minimum tread depth of 6 inches (152 mm) at any point.
Within any flight of stairs, the greatest winder tread
depth at the 12 inch (305 mm) walk line shall not exceed
the smallest by more than 3/8 inch (9.5 mm).
