CheckItOut Posted September 6, 2007 Report Share Posted September 6, 2007 Most of the receptacles in the 1962 house I inspected today were not grounded. Only two wires going to the one recept that I pulled a cover off of. Certain rooms were had grounds but most did not. All rooms had 3 hole recepts - obviously not correct for the non-grounded rooms. What year were grounded recepts required? Link to comment Share on other sites More sharing options...
John Dirks Jr Posted September 6, 2007 Report Share Posted September 6, 2007 They started changing over in the early 60's. My house was built in 62 and was done as a grounded 3 prong system. Link to comment Share on other sites More sharing options...
Chad Fabry Posted September 6, 2007 Report Share Posted September 6, 2007 Late 60's in my neck of the woods. Link to comment Share on other sites More sharing options...
hausdok Posted September 7, 2007 Report Share Posted September 7, 2007 Hi, Yeah, WJ, I caught myself writing that a few years ago and had to retrain myself to stop calling them the wrong term. Around here, it was about 1962 - 63. Sometimes homes from those few years will be confusing because some of our 60's homes still have K & T in the attics. You go through the entire house and find things grounded and then you get in the attic and discover the K & T and realize that all of the ceiling fixtures at the ceiling plane beneath the attic are ungrounded. I've also run into homes from the 62 - 63 timeframe where there are two-slot receptacles on 2-conductor NM with separate equipment-grounding conductors that end on screws in the back of the metal receptacle boxes. With these, a wiggy confirms that the boxes are in fact grounded and one of those 3 to 2 adapters would actually work if the pigtail is secured to the cover screw as it's supposed to be. It's a little counter intuitive - finding a house with fully grounded receptacles a separate equipment-grounding conductor and 2-slot receptacles. When I see those, I've suspected that maybe the electrician was just getting rid of a bunch of the old 2-conductor NM and 2-slot receptacles. This region seems to lag about 1 code cycle behind in most jurisdictions, so I think a reasonable range is about 1962 to 1964 to expect to still find 2-slot receptacles. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
randynavarro Posted September 7, 2007 Report Share Posted September 7, 2007 Originally posted by hausdok It's a little counter intuitive - finding a house with fully grounded receptacles a separate equipment-grounding conductor and 2-slot receptacles. When I see those, I've suspected that maybe the electrician was just getting rid of a bunch of the old 2-conductor NM and 2-slot receptacles. ONE TEAM - ONE FIGHT!!! Mike I wonder if it was because the metal boxes needed to be bonded back to the main panel--at least that's my theory. Link to comment Share on other sites More sharing options...
msteger Posted September 9, 2007 Report Share Posted September 9, 2007 I also use early 60s, but always noted it when I find ungrounded 3 wire type receptacles due to the potential safety issue. I recommend either changing these ungrounded ones back to 2 wire type, replacing with GFCI labeled no equipment ground, or have a licensed electrician rewire these receptacles. Link to comment Share on other sites More sharing options...
