snydl0ga Posted March 21, 2004 Report Posted March 21, 2004 I was looking at the different codes for recptacles and I may be confusing that with "outlets" but here is my question. In one paragraph I read that a kitchen must have at least two 20 amp small appliance circuits and that they can also supply the receptacles in the dinning room. Then I read another paragraph that states these two small appliances branches can not supply other outlets. Help me out...can I supply receptacles in other rooms from these?
hausdok Posted March 21, 2004 Report Posted March 21, 2004 Ultimately, it's up to what the rules are under the local code, but no, the only other areas that can be powered by these two circuits are the dining room and pantry and no lighting may be on them. ONE TEAM - ONE FIGHT!!! Mike
Richard Moore Posted March 21, 2004 Report Posted March 21, 2004 Lance... The "no other outlets" refers to lighting etc, as Mike pointed out. "Outlets" are undefined power taps while "receptacles" or "receptacle outlet" refers to the "thingies you stick a plug in" (technical term). So yes, you can feed the receptacles (and an electric clock) in a dining room from the kitchen small appliance circuit. If one of those receptacles then fed an exterior GFCI receptacle it would be wrong as that "space" isn't listed in 210.52(B)(1).
Paul MacLean Posted March 21, 2004 Report Posted March 21, 2004 And technically, the kitchen GFCI protected receptacles in the breakfast area, etc. should be labeled "GFCI Protected Outlet". Most around here are not labeled and I write up the lack of labeling. I think the homeowner needs to know. I've gotten into the habit of testing those breakfast or dining area receptacles for GFCI protection in newer construction just to see if the eletrician wired them on the small appliance circuit.
mcramer Posted March 22, 2004 Report Posted March 22, 2004 Originally posted by Paul MacLean And technically, the kitchen GFCI protected receptacles in the breakfast area, etc. should be labeled "GFCI Protected Outlet". Where does it say that in the NEC? (Hint: It doesn't)
Paul MacLean Posted March 22, 2004 Report Posted March 22, 2004 Originally posted by mcramer Originally posted by Paul MacLean And technically, the kitchen GFCI protected receptacles in the breakfast area, etc. should be labeled "GFCI Protected Outlet". Where does it say that in the NEC? (Hint: It doesn't) So Mark, I guess you're saying labeling GFCIs is not a good idea? Unfortunately I can't find my source for the labeling of GFCIs (I didn't say it was the NEC), but labeling is consistently done in new construction here. The "GFCI Protected Outlet" label can sure help avoid a lot of confusion and I will continue to recommend it where appropriate.
Norm Posted March 22, 2004 Report Posted March 22, 2004 Paul, I don't think Mark said it wasn't a good idea. I believe he said it wasn't required by the NEC. If you read the NEC I think you will find many things which would be a "good idea" which aren't required. Unfortunately the code making panels are, for the most part, far behind the times. Prime example: GFCI protection is not required in a laundry room with a slop sink even if it has a countertop. I defy you to explain the difference between the above location and a kitchen sink or a wet bar sink in terms of the consequences encountered when using all of the above. NORM SAGE
Darren Posted March 23, 2004 Report Posted March 23, 2004 Another question along these lines... It is acceptable to tie the outlet that serves the oven into the GFCI counter-top circuit? Darren
