JesseWBryant Posted August 18, 2007 Report Posted August 18, 2007 Do you guys call out openings greater than 4" for a guardrail that is at grade or less than 30". I know the intent is to prevent children from falling through but is the requirement also intended to prevent them from getting their little cabeza's stuck?
Mike Lamb Posted August 18, 2007 Report Posted August 18, 2007 I wouldn't. However, I believe guards should be installed at 24" (Chicago's standard) or even less as a simple safety issue.
JesseWBryant Posted August 18, 2007 Author Report Posted August 18, 2007 I agree. I wouldn't want to accidentally step off of a 28" patio, deck etc. and suffer a hyper-extended knee or other injury. Sometimes I'll add an FYI for safety if the drop off is just under 30"
John Dirks Jr Posted August 18, 2007 Report Posted August 18, 2007 I would mention that the standards have changed. 6" was previous and now it is 4". They paid for information so give it to them. In the end its up to them as to what to do with the info.
Jim Katen Posted August 18, 2007 Report Posted August 18, 2007 Originally posted by JesseWBryant Do you guys call out openings greater than 4" for a guardrail that is at grade or less than 30". I know the intent is to prevent children from falling through but is the requirement also intended to prevent them from getting their little cabeza's stuck? That's a good question. Is it even a guardrail if it's, let's say, one foot off the ground? - Jim Katen, Oregon
