Hi Kurt,
It's lick 'n stick. I see that same cast stone all the time here. It would really look better with a piece of flashing at the horizontal transition, but I don't think the lack of one is going to make a difference. This stuff is like stucco - it's applied to a mud-wire lath base over paper and it's designed to drain. Even without the flashing, water simply runs past it and leaves the wall at the bottom as it's supposed to.
OT - OF!!!
M.
If the scratch coat extends up under the casing then the casing is effectively counter flashing the scratch coat. Right?
There might be a concern only if the scratch coat terminates at the transition don't you think?
Chris, Oregon
While it would look for finished and esthetically pleasing with some flashing there, the scratch coat doesn't need to extend up behind the casing. The point I was trying to make is that they don't really need to be flashed because, if they're installed properly, the wall will drain very well.
OT - OF!!!
M.
You know, I can't ever recall having seen "lick & stick", and don't honestly know what it is. I know how real stone works (I live in a masonry city), but haven't the foggiest about this stuff....
Anyone got some brand names or links for me to look over?
Here you go http://www.culturedstone.com/
Also this is a link to a diagram that just about covers everything that this post is about.
http://www.culturedstone.com/technical/ ... etail4.asp
I put a bunch of it on my house when I built it. We like the look of stone, but didn't have budget for it. I twisted the arms of a few friends and family for help, and we put it up with only a couple of very basic instruction sheets (I didn't even have internet at the time). I actually enjoyed it, except for what the mortar did to my fingers over the days we were working on it.
That stuff is tougher than you might think. Just 6 months after moving in we had a helluva storm come through. A 90 foot pine tree out back went down into the roof of the master suite, finally stopped by the top plate of one of the lick & stick walls. Two pieces were knocked off; maybe three or four busted. That was it. I was impressed.
Brian G.
Rockin' the House [:-party]
Kurt,
It performs about the same as stucco. Two layers of 60-minute paper, some wire lath, mortar and then the stones are pushed into the mortar. The whole thing is supported temporarily on a wood cleat attached to the side of the house. Sometimes they'll bolt a steel anchor to the wall to support it.
Think hardcoat stucco with really big aggregate.
No Chris,
It isn't stucco, it is like stucco in the way it is installed on a bed of mortar, on lath, over two layers of paper. I think you could call it a "type" of masonry veneer. I think the stuff in your pictures will drain well even without a weep screed. However, when the joints are struck and smoothed there needs to be a way for moisture to get out as with masonry veneer or stucco.
  • 1 year later...
