My training says that a recirculating exhaust fan can only be installed above an electric range, but that the exhaust fan over a gas range must be vented to the exterior. FWIW, the exhaust fan is part of an over the range microwave, in new construction.
Can anyone post a code reference (IRC or Cabo if applicable. Any other codes will do) that makes this requirement, or am I off my rocker? (That may be a whole different thread) I know the manufacturer specs may require this as well.
If possible, please cut and paste the applicable code so that I can reference it to a builder, as I do not have access to my code books at the time being.
Any help would be appreciated,
David Fogle
HomeScope
Augusta, Ga.
I (almost) never see a exterior vented hood be it gas or electric. Takes the fumes, runs it through a cheap metal washable filter and blows it back in your face.
In realtorspeak - Helps cool you off while your cooking!
Know of no code that requires venting of a gas range.
As I think about it though, a lot of misconception abounds when it come to gas and CO. Gas, which burns clean, when burned correctly, is not a hazard when it comes to CO. You could leave a burner run on your stove top, with enough combustion air, and it wouldn't pose a CO threat ever.
I frequently get oriental client's. They cook with a lot of oil and want a range hood that vents outside the structure. I know it's not a code requirement, but I write it up under the theory that they're paying for my opinion. My opinion is range hoods should vent outside.
Here is a little experiment you can perform that will surprise you.
Zero your CO Detector
Turn on the gas range and measure
Get a pot of cold water and place it on the burner
Now measure.
SURPRISE! [:-bigeyes]
So do you need a vented hood and fan over a GAS range?
Now, go ask a professional cook that uses them for a living.
I turn my fan on PRIOR to using my gas range and stove.
Next one I buy will be electric.
Rob and Terry are both right. If a gas burner is perfectly tuned, it will not produce any CO. However, once the flame is impinged by placing a pot on the burner, it will make some CO. If the burner is not perfectly adjusted, it gets worse.
Tryptophan isn't the only reason you get sleepy after Thanksgiving dinner.
