Jerry Simon Posted August 3, 2007 Report Posted August 3, 2007 This doesn't say exactly why, and of course they're selling something, but it does claim tinning copper wire makes soldering easier. Perhaps it ain't entirely a myth. http://www.smallparts.com/products/descriptions/a32.cfm And then there's this... http://www.cast-lighting.com/art-tin-coat.html
Jim Katen Posted August 3, 2007 Report Posted August 3, 2007 Originally posted by Jerry Simon This doesn't say exactly why, and of course they're selling something, but it does claim tinning copper wire makes soldering easier. Perhaps it ain't entirely a myth. http://www.smallparts.com/products/descriptions/a32.cfm And then there's this... http://www.cast-lighting.com/art-tin-coat.html I guess they haven't heard of flux. - Jim Katen, Oregon
Terence McCann Posted August 4, 2007 Report Posted August 4, 2007 Originally posted by Jim Katen I guess they haven't heard of flux. - Jim Katen, Oregon Isn't that a State?
stubrooks Posted September 12, 2007 Report Posted September 12, 2007 In the electronics world, pre-tinning is done on almost all soldered wiring and components. It makes soldering faster reducing the amount of time needed to apply heat to the soldered components. Thereby reducing the possibility of heat damage in general and reducing the chance of solder wicking up a wire and under the insulation. Pre-tinning uses flux and the soldering process also uses flux. I still have a tinning pot in my colleciton of electronic assembly gear. A bar of solder is melted in a heavy metal pot. A stripped wire end is dipped in liquid flux and then dipped in the melted tinning solder.
Jim Katen Posted September 12, 2007 Report Posted September 12, 2007 Originally posted by stubrooks In the electronics world, pre-tinning is done on almost all soldered wiring and components. It makes soldering faster reducing the amount of time needed to apply heat to the soldered components. Thereby reducing the possibility of heat damage in general and reducing the chance of solder wicking up a wire and under the insulation. Pre-tinning uses flux and the soldering process also uses flux. I still have a tinning pot in my colleciton of electronic assembly gear. A bar of solder is melted in a heavy metal pot. A stripped wire end is dipped in liquid flux and then dipped in the melted tinning solder. All true. But that isn't the primary reason that old rubber-insulated wires were tinned. They tinned the copper to prevent it from reacting to the sulfur in the rubber. Sulfur compounds attack copper. -Jim Katen, Oregon
