I found this copper tubing in a garage protruding from the slab adjacent to the water heater. There is a floor drain a few feet away. No fuel oil residue or odor at the line. I think it's to prime the trap.
How do you write this up? Have a plumber reconnect the garage floor drain trap primer piping?
Image Insert:
51.9 KB
Chris, Oregon
Before I'd call that a trap primer, I'd figure out a way to squirt some water into it and see if the water comes out in the trap.
It sure looks exactly like an oil line.
Actually the house was 1973 ranch.
There was only one line. Typically here one line for an above ground tank and two for a buired tank. I could find no second line. Also the line was clean with no oil residue or odor.
Chris, Oregon
Originally posted by Terence McCann
I don't think that's a trap primer Chris. I've never seen a trap primer up here except for commercial HVAC applications where the trap is buried in a chase. Have you seen many in your neck of the woods?
Trap primers are very common here, particulary in the basements of older homes. Most of them are disconnected. I've never seen one in a garage.
Originally posted by chicago
Just a thought but is it possible it ran gas to the yard?
Good thought. Propane is often run in copper tubing. Might that once have been a propane water heater?
