Originally posted by AHI
Instead of lighting a match or a lighter, are there other simple ways of testing for proper flue draft? I would rather not fill the house with the sulfer smell.
Hold a small mirror near the flue. (at the draft hood or draft diverter) If it's backdrafting, the mirror will fog up.
In a pinch, use your fingernails. Moisture will condense on them.
There is a tool designed for just that purpose, but you have to drill a hole in the vent pipe to use it (it's called a "draft gauge").
Brian G.
Wayyyyy Beyond the Standards [:-bigeyes
You can feel, with your hand, spill over by the hoods too. I always give the stack some time to warm up before I check for proper draft. Hot water tanks have a habit of back drafting a bit before the flue/chimney gets warmed up (at least up North).
