Scottpat Posted July 16, 2007 Report Posted July 16, 2007 Question for the group. You have a wooden deck attached to a home. The deck has 5 steps that go to the backyard. Is a concrete landing or any type of landing needed at the bottom of those steps?
hausdok Posted July 16, 2007 Report Posted July 16, 2007 Hi Walter, I'm not sure why that didn't work for you; it should have, unless the file is too large. I think you're referring to the Gwinnet County deck guidelines that you used to tell folks about on the ASHI forum. If so, we've got it linked here on TIJ. Scott, all you had to do was click on "home," put "decks" into that search box on the front page, and then search "all forums" and you would have found everything you needed, including the links below, in about 20 seconds. http://www.eng.vt.edu/pdf/upload_files/Deck%20Specs.pdf http://buildingcodes.jocogov.org/docume ... 20Book.pdf http://www.co.gwinnett.ga.us/department ... etails.pdf http://www.fairfaxcounty.gov/dpwes/publ ... etails.pdf Walter, what browser are you using; Internet Explorer, Netscape or Firefox? Let me know, so I can try and figure out what the glitch is. ONE TEAM - ONE FIGHT!!! Mike P.S. I'm in the process of putting stuff into the file library. It's not happening very fast, because I don't have a staff and the time I have available to do it is limited. There's a ton of stuff here on TIJ that has to be uploaded to that file. For instance, searching .pdf produces 15 pages of posts where there are pdf files linked - all of which I want to eventually get uploaded into the library, along with every .pdf file that I've got archived on my own box. Do I have any volunteers that have time on their hands and want to help?
Jim Katen Posted July 16, 2007 Report Posted July 16, 2007 Is there any good reason why a level section of soil can't fulfill the requirement for a landing? - Jim Katen, Oregon
Scottpat Posted July 16, 2007 Author Report Posted July 16, 2007 Thanks Mike, I understand how the search works but I could not find a requirement for a landing on an exterior deck. I could find a section that says it is recommended but not required. In the IRC it does not define the stairs as deck stairs. But if you look at the section for Guards is specifies Decks. This is why I was wondering if the same requirements hold true for exterior landings . You have a landing from the house, and that is the deck. You then have stairs from the deck to the backyard. What if you have steps from that landing down the hill in the yard, do you need a landing at the bottom of those steps? I know this sounds silly, but it could be a never ending process. I'm with Jim. Why can't a level section of soil serve as a landing.
hausdok Posted July 16, 2007 Report Posted July 16, 2007 Dunno, Level sections of yard are used for the "landing" all the time around here. If the stairs are consistent in height, I only call them if they haven't placed something beneath the stringers to prevent earth-to-wood contact. ONE TEAM - ONE FIGHT!!! Mike
Bob White Posted July 16, 2007 Report Posted July 16, 2007 Originally posted by Mike Lamb IRC Sec. R312 says you need one. Actually, it's: R311.5.4 Landings for stairways. There shall be a floor or landing at the top and bottom of each stairway. (exceptions omitted) Wy wouldn't a flat yard serve as a landing? I'm with Jim and Scott on this one. As long as the deck steps are on a footing or footings, a level yard meets the requirement for a landing (except for Gwinnett County.)
SonOfSwamp Posted July 16, 2007 Report Posted July 16, 2007 Originally posted by hausdok Hi Walter, http://www.co.gwinnett.ga.us/department ... etails.pdf Walter, what browser are you using; Internet Explorer, Netscape or Firefox? Let me know, so I can try and figure out what the glitch is. ONE TEAM - ONE FIGHT!!! Mike IE7 on Vista Ultimate. Could be a Vista security thing that I haven't encountered yet. Pointer doesn't change to a hand when I hover over the paper-clip icon. You are correct; I was referring to the Gwinnett Co. GA deck specs, which are beautifully drawn and easily understandable. There's also a note that claims that the specs conform to the (presumably 2000) IRC. I've seen the VA deck specs. I think the GA specs are much more useful. I used to hand out a copy at every new-house job. WJ
