John Dirks Jr Posted July 15, 2007 Report Posted July 15, 2007 I have an outlet tester that has the GFCI test button. Obviously I would use this feature when testing a GFCI outlet. How about pushing this button even at non GFCI outlets? I figured that sometimes there are GFCI installed at the main panel. Pushing the button on my tester at non GFCI outlets should tell me if the outlet is on a GFCI protected circuit. Is my assumption correct?
Bill Kibbel Posted July 15, 2007 Report Posted July 15, 2007 Yes - it should trip any GFCI device upstream of the outlet being tested. Sometimes it's lotsa fun trying to find it after it trips.
John Dirks Jr Posted July 15, 2007 Author Report Posted July 15, 2007 Originally posted by inspecthistoric Yes - it should trip any GFCI device upstream of the outlet being tested. Sometimes it's lotsa fun trying to find it after it trips. Yeah, if its an occupied property I guess I better warn the owners in advance huh? Maybe ask them to shut down the computors and prepare to reset the clocks. I guess I could reset the clocks.
AHI in AR Posted July 15, 2007 Report Posted July 15, 2007 Originally posted by inspecthistoric Yes - it should trip any GFCI device upstream of the outlet being tested. Sometimes it's lotsa fun trying to find it after it trips. Those things can be a real pain. I dutifully tested the garage outlets in a home once only to have the master outlet trip. Usually, it's not too far away. Right? Not this time. An hour later I found it. The rocket scientist who wired the home--all 3 stories of it--put it in the attic. I had to find it since there was a freezer in use in the garage. The owner had no clue where it was. As a last resort, I went back to the attic and started moving the boxes of Christmas decorations, etc. There it was, nowhere near the furnace or anything else requiring an outlet.
elw351 Posted July 16, 2007 Report Posted July 16, 2007 it can be alot of fun to find. did a house with a boat house. i like to never found the outlet that was tripped.
