Chris Bernhardt Posted July 4, 2007 Report Posted July 4, 2007 According to the electrical inspection of existing dwellings, "appliances larger the 1/8 horsepower require a disconnecting means so the appliance can be safely worked on with the power off." When you find hardwired in appliances larger the 1/8th horsepower with no disconnecting means in sight nor some breaker lock off device at the panel do you write it up? Chris, Oregon
Scottpat Posted July 4, 2007 Report Posted July 4, 2007 What appliance would you find in a home that would have a motor larger than 1/8 horsepower. About the only thing I could think of would be a disposal or hydromassage pump, and those have disconnects when I find them.
Chris Bernhardt Posted July 4, 2007 Author Report Posted July 4, 2007 Well, every new house I inspect has several lockoff devices in the panel. Of course older homes typically don't have any. I was wondering how many inspectors write up the absence of lockoffs etc. on older homes for example as a safety improvement. Chris, Oregon
Jim Katen Posted July 4, 2007 Report Posted July 4, 2007 Originally posted by Chris Bernhardt According to the electrical inspection of existing dwellings, "appliances larger the 1/8 horsepower require a disconnecting means so the appliance can be safely worked on with the power off." When you find hardwired in appliances larger the 1/8th horsepower with no disconnecting means in sight nor some breaker lock off device at the panel do you write it up? Chris, Oregon I always flag missing disconnects or lockouts at air conditioners, furnaces, heat pumps and whirlpool baths. I'm less inclined to nag about that one on disposals and dishwashers, particularly on older homes. I know; it's inconsistent. - Jim Katen, Oregon
Richard Moore Posted July 4, 2007 Report Posted July 4, 2007 Unless it's a hard-wired batch processing disposal the NEC allows the wall switch to serve as the disconnecting means (always assuming I'm reading the code correctly). I'm with Jim regarding older houses for interior appliances. The NEC wording is "capable of of being locked in the open position". As most breakers are "capable" of being fitted with a lockout device, even if not currently present, I don't see that it's a big deal. If the guy replacing the dishwasher every 20 years is that nervous about homeowners going to the panel and deliberately trying to electrocute him, then he probably carries a selection of lock-outs. I see a need for them during construction but much less so once everything is installed and the panel is under the control of the homeowner. I don't think Jim is being "inconsistant". He's just applying common sense to the situation.
